HI,
I have figured out how to create a clone copy of an existing snapshot using the "create_clone.py" python script, but I have been unable to determine how to get created drive to show up as an available NFS mounted disk.
At the moment the only way I can do it, is if I go through the web GUI interface or through command line and mount the created volume and assign a path.
Is there a way to do this step via the API interface either using Linux curl command or using python??
TIA,
James
