Hi All
Had a case open with VEEAM and NetApp neither of which is going anywhere pretty quickly, so will throw it out there and see if anyone has any ideas.
We have a large estate broken down in to areas which mirror the configuration of each other so a nice lot of reference points.
There are 16 Tb NetApp LUN and 16TB volumes mapped to Veeam backup servers.
These LUNS and volumes serve no other purpose or function.
The client wrote a lot of data to this back up location and took it offline. So we cleared snapshots down and brought it back online.
When the mapped drive was browsed it could be seen there was a lot (TBs + TBs) of “Dead” VM backup files VEEAM advised these could be deleted which they were.
However the adjustment hasnt carried through to the storage end
VEEAM UI thinks there is 11.9 Tb free NetApp only 2 Tb ** After Storage Snapshot removal
Have stopped the VEEAM jobs
reset the storage password in VEEAM
Re-scanned the storage in VEEAM
Re-scanned the appropriate repository. in VEEAM.
NetApp side it thinks the volume is at capacity from the command line or from within On Command
Both also show the same Snapshots.
Its like there is a really old Snap out there locking the capacity but its just not showing up anywhere...
Any thoughts at all ..?
