We are testing some functionality in the new REST API, and I have been having issues with updating volume comments on a couple filers. Filers I have tested on are running:
NetApp Release 9.7P11D1: Wed Jan 27 17:40:19 UTC 2021
NetApp Release 9.7P8: Thu Oct 15 04:11:57 UTC 2020
NetApp Release 9.8P4: Mon May 03 09:22:00 UTC 2021
I suspect there is some issue with the job control in some way, but I have not been able to verify. Have poked around in logs in systemshell as well as checked 'job history show' for any clues. I submitted a case to Support and they suggested I ask here.
The program I am using to do the updates:
import netapp_ontap
from netapp_ontap import config, HostConnection, NetAppRestError, utils
from netapp_ontap.resources import Svm, Volume, Aggregate, VolumeMetrics, Cluster, Node, CLI
from pprint import pprint as pp
import logging
logger = logging.getLogger()
logger.setLevel(logging.DEBUG)
ch = logging.StreamHandler()
ch.setLevel(logging.DEBUG)
logger.addHandler(ch)
utils.DEBUG = 1
utils.LOG_ALL_API_CALLS = 1
naauth = {'username': <USER> , 'password': <PASS>}
admin = <FILER>
with HostConnection(admin, verify=False, **naauth):
netapp_ontap.host_connection._HOST_CONTEXT.port=<PORT>
resource = Volume(uuid='dbdccb94-c936-11eb-b0cb-00a098ce3ae6')
resource.comment = "testingacomment"
result = resource.patch()
if result.is_err:
logger.error(f"Volume Comment Update Failed - {result.http_response.status_code} - {result.http_response.reason}")
The Responses from the API:
-----------REQUEST-----------
PATCH https://[filer]:[port]/api/storage/volumes/dbdccb94-c936-11eb-b0cb-00a098ce3ae6
User-Agent: python-requests/2.26.0
Accept-Encoding: gzip, deflate
Accept: */*
Connection: keep-alive
X-Dot-Client-App: netapp-ontap-python-9.9.1.0
Content-Type: application/json
Content-Length: 30
b'{"comment": "testingacomment"}'
-----------RESPONSE-----------
202 Accepted
Date: Tue, 07 Sep 2021 16:22:57 GMT
Server: libzapid-httpd
X-Content-Type-Options: nosniff
Cache-Control: no-cache,no-store,must-revalidate
Content-Length: 189
Content-Type: application/hal+json
Keep-Alive: timeout=5, max=100
Connection: Keep-Alive
"job": {
"uuid": "dccd0527-0ff7-11ec-bbe3-00a098ef3e3a",
"href": "/api/cluster/jobs/dccd0527-0ff7-11ec-bbe3-00a098ef3e3a"
https://[filer]:[port] "GET /api/cluster/jobs/dccd0527-0ff7-11ec-bbe3-00a098ef3e3a?fields=message%2Cstate HTTP/1.1" 200 220
GET https://[filer]:[port]/api/cluster/jobs/dccd0527-0ff7-11ec-bbe3-00a098ef3e3a?fields=message,state
Accept: */*
None
200 OK
Date: Tue, 07 Sep 2021 16:22:58 GMT
Content-Length: 220
Keep-Alive: timeout=5, max=99
"state": "failure",
Job (failure): entry doesn't exist. Timeout remaining: 30.
