PSU1 FRU is not present in the chassis alert message was show on node A. I tried unplug and plug again the PSU, but alert still here. SP was tried reboot before, may i know what is the next step i can do. Many thanks.
logging as below:
WXXXXXXXXXX::> system health alert show
Node: WXXXXXXXXX-B
Resource: PSU1 FRU#042012002634
Severity: Critical
Indication Time: Mon Sep 06 07:02:21 2021
Suppress: false
Acknowledge: false
Probable Cause: PSU1 FRU is not present in the chassis 042012002634.
The nodes in this chassis are WXXXXXXXXX-A.
Possible Effect: The nodes in the chassis might not function
effectively or redundancy might be lost.
Corrective Actions: 1. Plug in PSU1 FRU correctly into the slot.
2. Refer to the Hardware specification guide for more information on the position of the field-replaceable unit (FRU) and ways to check or replace it.
3. Contact support personnel if the alert persists.
event show:
monitor.fan.failed: Multiple fans has failed.
monitor.fru.info.unreadable: The inventory information of FRU PSU2 is not readable.
monitor.fru.info.unreadable: The inventory information of FRU PSU1 is not readable.
callhome.c.fan.fru.fault: Call home for CHASSIS FAN FRU FAILED: Multiple fans have failed
monitor.temp.unreadable: The controller temperature (Midplane 1 Temp) is not readable.
monitor.temp.unreadable: The controller temperature (Midplane 2 Temp) is not readable.
monitor.temp.unreadable: The controller temperature (Midplane 3 Temp) is not readable.
monitor.temp.unreadable: The controller temperature (Midplane 4 Temp) is not readable.
