Where can I find my past work?
check here -> http://www.certmetrics.com/netapp/login.aspx
There's no need to yell here 🙂
I've edited the all-caps text from your post and moved it to the NetApp Learning Services space.
There are multiple repositories, depending upon the desired records that you want to access.
To view your completed NetApp Learning Services coursework, go to the NetApp LearningCenter:
https://learningcenter.netapp.com Navigate to ME->Completed Learning
To view your active and expired certification details, exam history, download certification logos, et al., go to the NetApp CertCenter:
https://www.certmetrics.com/netapp/login.aspx
To view your Pearson VUE score reports, exam appointment history, et al., go to the NetApp exam program's homepage:
https://home.pearsonvue.com/netapp
