Hi All,
We check the Solidfire display below error, I can found NetApp KB "NVRAM device problems detected, metadata drive will be removed" but the error not same as "error=deviceCapacitanceOffThePack", should I require open support case?
nvramDeviceStatus
NVRAM device problems detected, metadata drive will be removed. Contact NetApp support, error=deviceCapacitanceOffThePack 3.926F
Best rgeards,
Chung
