i ml using FAS80X with 9.7P16
i have ran the command
storage disk show -fields power-on-hours
and i found a disk that is runnong 131058
more than 14 years.
and i m a bit surprised
can i trust really this counter?
There is a bug related to this already, depending on the disk model: 1414849
There is presently no workaround or solution to this.
Obviously no. I'd ensure your disk firmware is updated, and if it is, then open a case so we can log a bug.
Hi
thanks for your reply.
i can't access to the bug.
well i guess i will live with that
