Is the pin-out the same like https://www.ibm.com/docs/en/nseriesexpansion/com.ibm.nseries.hardware.doc/exn3200isi/PRMA-0402-000.pdf (Appendix A/Exhibit A-1)?
Damn, If I saw this yesterday I may tested it. I just pulled power cables from 8 ATTO bridges.
From the install pdf.
Using the serial port1 Connect a cable from FibreBridge RS-232serial port to the serial (COM) port on apersonal computer.2 Turn on the FibreBridge.3 Start a terminal emulation program on thepersonal computer, and use it to connect to theFibreBridge. For example, if you are usingHyperTerminal on a computer running aWindows operating system,a. Type FibreBridge in the NewConnection dialog box.b. Click OK.c. In the Connect To dialog box, for theConnect using field select the COMport number to which your serial cableis connected.d. Click OK.e. In the COM Properties dialog boxselect the following values:• Bits per second: 115200• Data Bits: 8• Parity: None
Sry, but I had no time for that bullshit. I ordered two IBM V7000 Control Enclosure which worked the next day and shipped those two FibreBridges to NetApp Deutschland GmbH, Sonnenallee 1, 85551 Kirchheim bei München for maintenance.
Ah, great, returned to sender without even opening the box?
What are you telling me again??
Hi, for repair and troubleshooting you will need to open a support case for the serial number. What Sanaman wrote above should we working without any issue.
