Is there a maximum number of files and depth in one process (SCAN / COPY / SYNC / Verify)?Is there anything else I should be aware of?
Hello,
You can use the -depth to limit the search depth to n levels. As for the maximum number of files, The maxdir size (default is 308MB) defines the maximum file count (approximately one million) ina single folder. Increase the maxdir size value to increase the file count. Increasing the value willhave an impact on additional CPU cycle.
You can check additional prerequisites for XCP in the link below P. 5-6:
https://www.netapp.com/media/20029-tr-4863.pdf.
Thanks
Hello hmoubaraThank you for your reply
The link destination could not be referenced.
NFS SCANThe default isMaxdir = 308MBFiles = about 1 millionI understood.I understand that the above can be changed by changing "-depth".
There seems to be no "-depth" in other NFS options or CIFS.Is there an upper limit in this case?It may be in the linked PDF document, but I can't refer to it.
Sorry i had an extra dot
Hello
hmoubara
Thank you.
I could access it.
No description was found for the upper limit.
