Hi,
we buy a new FAS2720 with 4 SSD and 8 HDD and 3 DS212C with 12 HDD each, for a total of 4 SSD 960GB and 44 HDD 4TB.
Now I'm configuring Flash Pool, like the old FAS2554 (4 SSD + 20 HDD) that will be migrated on the new FAS.
So I use the same command use some years ago on the 2554:
storage aggregate modify -aggregate cluster4_01_NL_SAS_1 -hybrid-enabled true
storage pool create -storage-pool StoragePool_c4_Cache1 -disk-list 1.0.0,1.0.10,1.0.1
now
storage aggregate show-spare-disks -disk-type SSD
show one disk as spare on node02 (the same as 2554).
Original Owner: cluster4-02
Pool0
Spare Pool
Usable Physical
Disk Type Class RPM Checksum Size Size Status
1.0.11 SSD solid-state - block 894.0GB 894.3GB zeroed
But when I try to add flash-pool to aggregate I have this error:
storage aggregate add cluster4_01_NL_SAS_1 -storage-pool StoragePool_c4_Cache1 -allocation-units 4 -raidtype raid4
Error: command failed: storage pool "StoragePool_c4_Cache1" does not have enough spare allocation units. Use "storage pool show-available-capacity" to get the spare allocation units assigned to node cluster4-01.
Storage SyncMirror Allocation Unit Total
Node Storage Pool Type Pool Unit size Count Usable Size
cluster4-01
SSD Pool0 670.5GB 2 1.31TB
cluster4-02
2 entries were displayed. So, what is changed on FAS2720 and/or ONTAP 9.9.1? I remember that in the past an SSD spare can be shared from node.
Now I'm in difficulty if I cannot create my flash pool.
Thanks
