Hi All,
According to the ONTAP 9.10.1 documentation there is a way to convert a FlexVol volume to a FlexGroup Volume. I have updated my cluster to 9.10.1 recently however the conversion command is not listed in the CLI under volume options as it described in the docs.
https://docs.netapp.com/us-en/ontap/flexgroup/convert-flexvol-svm-dr-relationship-task.html
Did the conversion get omitted from the release?
Thank you,
Bela
Please ignore this post, the reason for not having the conversion option is not being in advanced mode.
