I need a netapp technical document that says 'no problem' with disabling SSH default port in 7-mode or default port coming out of port scan.
Is there anyone who can help me with the above?
Hi @wwetsx
Another user had a similar post which may be helpful.
https://community.netapp.com/t5/ONTAP-Discussions/why-cannot-change-ssh-service-port-to-user-define-port/m-p/139673
Hope this helps!
Not sure what you're looking to do, can you provide a bit more context on what your end goal here is?
I would like to know how to disable the existing default port when I change the ssh default port from 22 to 50022 in netapp 7-mode.Or we need the official technical document of netapp that the default port 22 is not disabled when we turn the port scan.
