I have configured an ontap 9.11.1 with NFS, when creating the volume and presenting it, it always gives me a permissions error. I have configured the following per cli
vserver nfs modify -vserver vserver_name -v3 enabled
vserver nfs modify -vserver vserver_name -v4.0 enabled
vserver nfs modify -vserver vserver_name -v4.1 enabled
vserver nfs modify -vserver vserver_name -tcp enabled
vserver nfs modify -vserver vserver_name -udp enabled
vserver nfs modify -vserver vserver_name -mount-rootonly disabled
vserver nfs modify -vserver vserver_name -nfs-rootonly disabled
vserver nfs modify -vserver vserver_name -showmount enabled
vserver export-policy create -policyname all_nfs -vserver nfs
vserver export-policy rule create -policyname all_nfs -clientmatch 0.0.0.0/0 -rorule any -rwrule any -superuser any -protocol nfs,nsf3,nfs4
vserver export-policy rule show -vserver nfs -policyname all_nfs
volume modify -volume Testing -vserver nfs -policy all_nfs
I need to be able to mount the volume, but the strangest thing is that a volume \! as the picture shows and check and is the nfs_root SVM
Thanks for your help
