To start I can't provide much insight as far as logs and such as this is a closed network. Although I know I need configuration help, I'm more looking for some information. Some backstories: The hardware is EOL (FAS3220) and has no maintenance and we are trying to migrate the data off so that we can setup our new FAS8300 and utilize the new equipment with support. Working with some smart guys at NetApp we came up with this migration plan of migrating to our new AFF300 first, decomming the FAS3220's, then setting up the FAS8300 and populating that with the FAS3220's data.
I have setup and install the 7MTT on my pc and have configured it so that I can see my filers, I select all the data I'm going to transfer and set up the schedules and the task gets created successfully. When run the precheck I get an error stating an intercluster-lif needs to be created, that's fine. I create it using the sporadic information available to me, on the AFF300. When I run the precheck then it successfully goes to start baseline. At which point I left for the weekend, when I came in Monday morning noticed that it had errored out and was still at the start baseline portion. I lost the error but the intercluster-lif seemed to be the point of contention.
What I'm asking for I guess is what is the proper procedure for this intercluster-lif creation? Do you create one on the remote 7-mode cluster and the Ontap cluster? Do the SVM's need one as well?
*Never received any Ontap training just picking up everything on the fly! XCP isn't bad but these FAS3220 are so bad if it's migrating with xcp and a developer hits the storage for a test it kicks everyone off and makes the shares inaccessible for like 15-20 mins.
