I've updated PowerShell Toolkit on my workstations and servers to versions later than 9.10.1.x (either 9.11.1.2208 or 9.12.1.2302) and now standard cmdlets do not work correctly unless using the legacy -ONTAPI switch. When I try to run something seemingly simple like Get-NCVol I get varying and/or missing results (see attachments). As far as I can tell the Get-NCVol uses the volume-get-iter REST API which has no mention that it is being deprecated or does not have a REST API equivalent from ZAPI. The same thing happens for other common cmdlets such as Get-NCAggr.
Am I missing something?
Thanks.
