Hello.
I have a simple question.
Our customers are currently using the FAS2720 equipment. I'm trying to convert my equipment into a FAS8300 because I can't expand my 460C Shelf anymore.
So we're going to use all of the disks on the existing FAS2720 on the FAS8300, and we want to make the data operational without a separate migration.
That's how I found the hardware upgrade documentation.
However, the NetApp support document 'Decide where to use the aggregate relocation procedure' does not indicate whether the FAS2720 -> FAS8300 can be supported.
It was only mentioned that it was possible to upgrade from the old 8000 series to the 8200 and 8300 series.
I would like to know if hardware upgrade support from FAS2720 to FAS8300 is possible, and if not, I would like to know if migration is required using 'snapmirror' or 'snapvault'.
Thank you.
