The Client has Volume Group with RAID-6 and one disk slot#22 was fail then by mistaken client removed 02 more disks in RAID, so volume group is in fail status, can any body help to recover/revive a volume group in Santricity 11.30
Original disks will be needed as well, but as indicated a support case should be raised as recovery will require the hot spares drives be unassign and running several commands to prevent reconstruction and complete recovery.
If the system is under valid support, then please call NetApp Technical Support or log into the NetApp Support Site to create a case.
