Hi,
Does anyone know if it's possible to create a network interface group using ports across two nodes like the top diagram? If possible, what's the cli commands?
Thank you!
A network interface group must be between a single netapp node and a single switch stack/cluster/LACP root.
Both diagrams represent valid configurations, assuming the top one is using VSS or some other stacking protocol between the switches.
Hope this helps.
Can you explain a bit more on what you mean? Here is the description of the top diagram:
NetApp Interface Group Supported Configurations
In the top example in the diagram, we have an Interface Group on Controller 1 which is connected to two different switches. We repeat this for Controller 2. We have two Interface Groups - a0a on Controller 1, and a0a on Controller 2.
This mean it's possible to create an interface group using one port from each controller?
Thanks!
Got it figure out. Thank you!
