I had putt gather from public forum. but its erroring with certificate. would appreciate any assistance.
[test-profile1]
aws_access_key_id=myAccessKey
aws_secret_access_key=mySecretAccessKey
import sys
import boto3
import boto3.session
## Configure the StorageGRID S3 endpoint and profile name ##
session = boto3.session.Session(profile_name='test-profile1')
endpoint = 'https://s3.mycompany.com:8080/'
# Ignore SSL verification
s3 = session.resource(service_name='s3', endpoint_url=endpoint, verify=False)
client = s3.meta.client
# Get the target bucket name from the command line argument
if len(sys.argv) < 2:
print("Please provide the target bucket name as a command line argument")
sys.exit(1)
target_bucket_name = sys.argv[1]
# Create an S3 client
s3_client = boto3.client("s3")
# create an S3 resource
s3 = boto3.resource("s3")
# Get a list of all S3 buckets
response = s3_client.list_buckets()
# Iterate over the buckets
for bucket in response["Buckets"]:
bucket_name = bucket["Name"]
# Check if the bucket name contains the target string
if target_bucket_name in bucket_name:
print(f"Found bucket: {bucket_name}")
versioning = s3_client.get_bucket_versioning(Bucket=bucket_name)
bucket = s3.Bucket(bucket_name)
if versioning.get("Status") == "Enabled":
bucket.object_versions.delete()
else:
bucket.objects.delete()
# Finally, delete the bucket
s3_client.delete_bucket(Bucket=bucket_name)
print(f"Deleted bucket: {bucket_name}")
execute the script - python search_bucket_and_delete.py test-bucket
ERROR - File "C:\Program Files\Python38\lib\ssl.py", line 1309, in do_handshake
self._sslobj.do_handshake()
ssl.SSLCertVerificationError: [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get local issuer certificate (_ssl.c:1108)
During handling of the above exception, another exception occurred:
Traceback (most recent call last):
urllib3.exceptions.SSLError: [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get local issuer certificate (_ssl.c:1108)
raise SSLError(endpoint_url=request.url, error=e)
botocore.exceptions.SSLError: SSL validation failed for https://s3.eu-west-1.amazonaws.com/ [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get local issuer certificate (_ssl.c:1108)
