Dear all
we have to install a new system FAS2720 with 12x 16TB NL-SAS with 2 controllers. Which is maximum used capacity that i can take from this configuration?
Thanks
George
To get the most out of this, you'll use the layout recommended by Fusion, which unless you're a partner you won't have access to. But give all the non-root drives to one node.
Hi John
thanks for your reply, the disks are shared between the 2 controllers and I can't use the RAID TEC because we must use min of 7 disks and in my case i have 6 disks per controller
G
Yes, you can use RAID-DP instead of RAID-TEC.
