I'm using C-mode Ontap 9.3 (soon to be 9.12!) and I have a volume that houses 300 CIFS shares. in total there are ~ 40 million files/folders on this volume
I have a requirement to create the following:
- An ADDS group that has list access to all directories
- An ADDS group that has read access to all files/directories
If I share out the root of this volume and add an NTFS ACL for this purpose it's taking over 60 hrs and counting to complete! This is because doing this over the CIFS protocol is incredibly inefficient.
Is there anyway I can set/modify/add NTFS permissions on this volume from the Filer1/vServer itself? I found the following article but it's not clear to me if this destroys existing NTFS permissions Configure NTFS file permissions using the ONTAP CLI (netapp.com)
