I have a couple of 9.5P6 VMs running on various versions of ESXi.Recently, I fired one up to do some development, and ran into the "FPolicy servers fail to authenticate due to CVE-2022-38023" problem (as detailed here: https://kb.netapp.com/onprem/ontap/da/NAS/FPolicy_servers_fail_to_authenticate_due_to_CVE-2022-38023 ) which meant I couldn't access its CIFS shares.The problem doesn't exist for later versions on ONTAP, but as far as I'm aware, 9.5P6 is the "last" version that is officially supported for ESXi (and I've tried downloading the 9.13 simulator OVA and deploying that on ESXi, but it fails)I've read that it's possible to upgrade a working instance of 9.5P6 on ESXi to later versions, but when I attempt to download an upgrade image (eg, from here: https://mysupport.netapp.com/site/products/all/details/ontap9/downloads-tab/download/62286/9.7P23) I get an "unauthorised access" page.Can anyone give me some advice on what they think the best way forward is? I suppose I could deploy a later simulator on VM Workstation on a Windows ESXi VM, but my experience of running other OS this way is that they are painfully slow.
Neil Anderson at Flackbox has a great tutorial to set up an entire environment, from network, mgmt, and cluster switches, to a 2 node cluster, a single node cluster, linux and win clients, and a virtual esx environment. All you need is vmware player although you could probably set it up using virtualbox or if you've got a license you can use esx desktop.
I've got it built on my laptop which has 16GB ram and an i7-1185G7 cpu running windows 11. The whole environment runs great on my system even when everything is up and running. I'm using vmware player.
His classes and all his NetApp stuff are here:
Thanks for the reply.Can other machines on your network access the ONTAP shares and cluster management interface OK?In an ideal world I'd have the vSim running directly on ESXi rather than on a Windows VMPlayer, but if that's the only option....
Thanks, but this doesn't really answer my question about upgrading an existing installation, or getting around the problem that versions later than 9.5P6 are not officially supported under ESXi.
