HI all,
after an NVRAM module ECC error/failure of a controller on a 2552 in 7 mode (HA) and subsequent replacement from another controller (cleanly shutdown supposedly), the controller now boots up (the other is in takeover) but won't go in "waiting for giveback" and complains about ownership of a couple of disks which have been reserved by the HA partner:
Mar 26 17:11:06 [localhost:diskown.isEnabled:info]: software ownership has been enabled for this system
Reservation conflict found on this node's disks!
Local System ID: 537074349
Mar 26 17:11:06 [localhost:cf.fmns.skipped.disk:notice]: While releasing the reservations in "Waiting For Giveback" state Failover Monitor Node State(fmns) module skipped the disk 0a.00.22 that is owned by xxxxxxxxx and reserved by yyyyyyyyy.
WAFL CPLEDGER is enabled. Checklist = 0x7ff841ff
Press Ctrl-C for Maintenance menu to release disks.
add host 127.0.10.1: gateway 127.0.20.1
Mar 26 17:11:09 [localhost:wafl.memory.status:info]: 2004MB of memory is currently available for the WAFL file system.
NOTE: You have chosen to boot the diagnostics kernel.
Use the 'sldiag' command in order to run diagnostics on the system.
Mar 26 17:11:09 [localhost:dcs.framework.enabled:info]: The DCS framework is enabled on this node.
The system has booted in maintenance mode allowing the
Mar 26 17:11:09 [localhost:cf.fmns.skipped.disk:notice]: While releasing the reservations in "Waiting For Giveback" state Failover Monitor Node State(fmns) module skipped the disk 0a.00.12 that is owned by xxxxxxxxx and reserved by yyyyyyyyy.
following operations to be performed:
Mar 26 17:11:09 [localhost:snmp.link.up:info]: Interface 8 is upMar 26 17:11:09 [localhost:netif.linkUp:info]: Ethernet e0P: Link up.
? acorn
Mar 26 17:11:09 [localhost:snmp.link.up:info]: Interface 1 is up
acpadmin aggr
Mar 26 17:11:09 [localhost:netif.linkUp:info]: Ethernet e0a: Link up.
cna_flash disk
Mar 26 17:11:09 [localhost:snmp.link.up:info]: Interface 2 is up
disk_list disk_mung
Mar 26 17:11:09 [localhost:netif.linkUp:info]: Ethernet e0b: Link up.
disk_qual disk_shelf
diskcopy disktest
dumpblock environment
fcadmin fcstat
fctest fru_led
ha-config halt
help ifconfig
key_manager led_off
led_on nv8
raid_config sasadmin
sasstat scsi
sesdiag sldiag
storage stsb
sysconfig systemshell
ucadmin version
vmservices vol
vol_db vsa
xortest
Type "help <command>" for more details.
In a High Availablity configuration, you MUST ensure that the
partner node is (and remains) down, or that takeover is manually
disabled on the partner node, because High Availability
software is not started or fully enabled in Maintenance mode.
FAILURE TO DO SO CAN RESULT IN YOUR FILESYSTEMS BEING DESTROYED
NOTE: It is okay to use 'show/status' sub-commands such as
'disk show or aggr status' in Maintenance mode while the partner is up
Mar 26 17:11:14 [localhost:snmp.link.down:info]: Interface 7 is down.
Mar 26 17:11:14 [localhost:netif.linkDown:info]: Ethernet e0M: Link down, check cable.
Continue with boot?
After continuing the boot it enters maintenance mode and checking the various statuses I get this:
*> aggr status
Aggr State Status Options
aggr0 online raid_dp, aggr root
degraded
64-bit
*> aggr show
Mar 26 17:59:18 [localhost:fmmb.current.lock.disk:info]: Disk ?.? is a local HA mailbox disk.
aggr: No such command "show".
Mar 26 17:59:18 [localhost:fmmb.current.lock.disk:info]: Disk 0a.00.2 is a local HA mailbox disk.
The following commands are available; for more information
Mar 26 17:59:18 [localhost:fmmb.instStat.change:info]: missing lock disks, possibly stale mailbox instance on local side.
type "aggr help <command>"
Mar 26 17:59:18 [localhost:raid.mirror.vote.versionZero:debug]: raid: mirror info empty
clear_rpbits options rename snaprestore_cancel
Mar 26 17:59:18 [localhost:coredump.host.spare.none:info]: No sparecore disk was found for host 0.
Halting and Rebooting with diags I get this:
LOADER-A> boot_diags
Loading X86_64/freebsd/image2/kernel:0x100000/9578776 0xa22918/4044416 Entry at 0x8016e880
Loading X86_64/freebsd/image2/platform.ko:0xdfe000/786856 0xf9bea0/724152 0xebe1c0/45064 0x104cb58/49752 0xec91c8/110791 0xee428f/80654 0xef7da0/172160 0x1058db0/195312 0xf21e20/16 0xf21e30/2448 0x10888a0/7344 0xf22800/0 0xf22800/344 0x108a550/1032 0xf22958/1952 0x108a958/5856 0xf230f8/1648 0x108c038/4944 0xf23768/240 0x108d388/720 0xf23860/448 0xf5e860/14942 0xf9bda2/253 0xf622c0/136824 0xf83938/99434
Starting program at 0x8016e880
NetApp Data ONTAP 8.2.4P6 7-Mode
Root mount waiting for: usbus0
Copyright (C) 1992-2017 NetApp.
All rights reserved.
md1.uzip: 39168 x 16384 blocks
md2.uzip: 16640 x 16384 blocks
* Press Ctrl-C for Boot Menu. *
Error burning Mellanox sinai chipset firmware.
^Cqla_init_hw: CRBinit running ok: 8c633f
NIC FW version in flash: 5.4.9
Mar 26 17:53:56 [localhost:sasmon.disable.module:info]: SAS domain is not monitoring transient errors.
Mar 26 17:53:58 [localhost:cf.nm.nicTransitionUp:info]: HA interconnect: Link up on NIC 0.
NIC FW version bundled: 5.4.56
Mar 26 17:54:03 [localhost:cf.rv.flush.handleExchange:info]: HA interconnect: Flushing is active.
Mar 26 17:54:05 [localhost:netif.linkDown:info]: Ethernet Wrench Port: Link down, check cable.
Mar 26 17:54:07 [localhost:snmp.link.down:info]: Interface 3 is down.
Mar 26 17:54:07 [localhost:netif.linkDown:info]: Ethernet e0c: Link down, check cable.
Mar 26 17:54:07 [localhost:snmp.link.down:info]: Interface 4 is down.
Mar 26 17:54:07 [localhost:netif.linkDown:info]: Ethernet e0d: Link down, check cable.
Mar 26 17:54:08 [localhost:snmp.link.down:info]: Interface 5 is down.
Mar 26 17:54:08 [localhost:netif.linkDown:info]: Ethernet e0e: Link down, check cable.
Mar 26 17:54:08 [localhost:snmp.link.down:info]: Interface 6 is down.
Mar 26 17:54:08 [localhost:netif.linkDown:info]: Ethernet e0f: Link down, check cable.
Mar 26 17:54:08 [localhost:diskown.isEnabled:info]: software ownership has been enabled for this system
Local System ID: xxxxxxxxx
Mar 26 17:54:08 [localhost:cf.fmns.skipped.disk:notice]: While releasing the reservations in "Waiting For Giveback" state Failover Monitor Node State(fmns) module skipped the disk 0a.00.0 that is owned by xxxxxxxxx and reserved by yyyyyyyyy.
Mar 26 17:54:11 [localhost:wafl.memory.status:info]: 2004MB of memory is currently available for the WAFL file system.
Mar 26 17:54:11 [localhost:dcs.framework.enabled:info]: The DCS framework is enabled on this node.
? acorn
acpadmin aggr
Mar 26 17:54:12 [localhost:snmp.link.up:info]: Interface 8 is up
cna_flash disk
Mar 26 17:54:12 [localhost:netif.linkUp:info]: Ethernet e0P: Link up.
disk_list disk_mung
Mar 26 17:54:12 [localhost:snmp.link.up:info]: Interface 1 is up
Mar 26 17:54:12 [localhost:netif.linkUp:info]: Ethernet e0a: Link up.
diskcopy disktest
Mar 26 17:54:12 [localhost:snmp.link.up:info]: Interface 2 is up
Mar 26 17:54:12 [localhost:netif.linkUp:info]: Ethernet e0b: Link up.
fcadmin fcstat
fctest fru_led
ha-config halt
help ifconfig
key_manager led_off
led_on nv8
sasstat scsi
sesdiag sldiag
storage stsb
ucadmin version
vmservices vol
vol_db vsa
xortest
Mar 26 17:54:17 [localhost:snmp.link.down:info]: Interface 7 is down.
Mar 26 17:54:17 [localhost:netif.linkDown:info]: Ethernet e0M: Link down, check cable.
Continue with boot?
So it now complains about another reserved disk a0.00.0 and no longer a0.00.22 and a0.00.12. Also it seems there is no defined mbox disk which I suppose is not good. The partner is in takeover and is working ok at the moment. Issuing a cf giveback doesn't work as the partner is not awaiting giveback (still need to get there hopefully).
Any advice is appreciated - thanks!
