Hi All,
Actually, We have a FAS2750 10 Gb Base T for NAS services. Due to a network upgrading, we need to change our 1 gb base T connection per 10 gb SFP.
Our Storage team are planning to change controllers FAS2750 10 Gb Base T per controllers FAS2750 UTA2 and we want to following the "Controller Module Replacement-FAS2700" from NetApp Docs. (https://docs.netapp.com/us-en/ontap-systems/fas2700/controller-replace-overview.html)
As you know, for this escenario it is not possible change only ethernet connections to UTA2 SFP connections using adapter cards without changing the controller.
My question is, will it work for us?
Thanks for your support.
