Hello Guys,Maybe somebody any experience for same this case?Please give me step for troubleshoot.
How is performance on the source/destination node? That first one will need to finish first. The other possibility could be BRE throttling, which is expected if latency is higher.
Lastly, how much i/o is going on with that volume? It might be so busy it can't finish a cutover.
Run ::> vol move show -instanceto see the actual "warning" state
Hello Paul,after we check performance source destination node
hello Jonathan,Fyi
where can i check snapshot capacity in node aggr_SASInternal
There may be room on disks but it could be reserved. Why are you moving to an already full aggregate? ONTAP won't perform well with being full.
