Hello!
New array deployment here. Former NetApp customer returning and looking to manage some aspects of day to day admin via the Netapp.ONTAP powershell modules. I have been unable to get connected and support suggested posting here.
if (Get-Module -ListAvailable -Name NetApp.ONTAP) {
Write-Host "NetApp Modules are installed..."
else {
Write-Host "NetApp Module does not exist....installing now...."
Install-Module -Name NetApp.ONTAP
# Variables
[Net.ServicePointManager]::SecurityProtocol = [Net.SecurityProtocolType]::Tls13
$NetAppArray='netapp01.domain.com'
$cred=$(Get-Credential)
# Connect to array
Connect-NaController -Name $NetAppArray -Credential $cred -HTTPSError as follows:
Connect-NaController : Connection to netapp01.domain.com using HTTPS failed - The request was aborted: Could not create SSL/TLS secure channel.
The error may be resolved by generating a new certificate on the storage controller, with a longer key length.
At O:\Network\Scripts\PowerShell\NetApp.ps1:17 char:1
+ Connect-NaController -Name $NetAppArray -Credential $cred -HTTPS
+ CategoryInfo : InvalidResult: (netapp01.domain.com:NaController) [Connect-NaController], NaConnectionSSLException
+ FullyQualifiedErrorId : HttpConnectionFailed,DataONTAP.PowerShell.SDK.ConnectNaController
Things I have tried:
Verified key length is 2048. I have tried forcing TLS 1.2 and 1.3 from powershell. Tried shortname/FQDN/IP. I have used the built-in self signed cert as well as a purchased digicert wildcard.
Some output from the array (run with 'set advanced'):
netapp01::*> security certificate show -fields size -type server
vserver common-name serial ca type subtype cert-name size
netapp01
netapp01 0C02639083A3E774E2E1B51125F1BB34
"DigiCert Global G2 TLS RSA SHA256 2020 CA1"
server - netapp01_wildcard2025 2048
netapp01
netapp01 17D48425558215B2 netapp01 server - netapp01_17D48425558215B2 2048
4 entries were displayed.netapp01::*> security config show -fields supported-protocols
interface supported-protocols
SSL TLSv1.3,TLSv1.2
Thanks in advance for any ideas.
