Hi:
I'm going to upgrade the storage system version from 9.5 to 9.13.1 in one day, what to be aware of and what are the risks
Thanks
All the information needed at ONTAP upgrade overview (netapp.com)
Make sure your platform support the latest code. If you are on 9.5 right now, you may not be able to go past 9.8 on certain platforms and 9.11 on other platforms. If you try to load unsupported code, bad things may happen!
starting at 9.5 definitely start with the latest 9.5P19 release. Then jump to 9.7P23 -> 9.9.1P20 -9.13.1P11.
For some versions ONTAP will let you apply two upgrades, but I have found it safer to just process one upgrade at a time and wait for it to finish.
WIth doing SO MANY updates, I like to go to th cluster command line:
set diag
system node upgrade-revert show
cluster show
storage failover show
I run those after every upgrade to be sure all nodes are good before starting the next.
Hello Chenguanghui,
Following these steps can help ensure a successful ONTAP upgrade.
I will put it again here:
Not every customer has the hardware inventory to build a test environment. After the upgrade, find a way to make it work. The "rollback" indicated above is a 100% outage to allow ONTAP to revert structures without any client access. Not fun.
The only platforms that support both 9.5 and 9.13.1 are the following:
A800
FAS9000
FAS8200
FAS2720
FAS2750
If your system is not one of those listed above, it will not support this upgrade.
