Hi All,
I just deploy a AFF C250 for the SAN purpose on one of my custom. But I need some technical advise or view on my current setup as after I setup the bos and present the iSCSI and do the failover testing after the iSCSI LUN already present in the VM, the LUN is missing on the server.
Here my current NetApp C250 setup and current physical connection.
Here is some summary of C250 configuration and also current environment overview.
Customer network overview and connection
- Management and ISCSI LIF is in the same network segment
- NetApp C250 node is connected to Cisco C9300 switch - for management (e0M) and iscsi LIF (e0a)
- Both Cisco C9300 have uplink to the same production core switch
- The VM which the iSCSI LUN mapped is one VM inside the Nutanix AHV
Failover Testing observation
Before failover testing by shutdown the node A
- View in the NetApp System Manager
- Current iSCSI LUN/Volume is located on aggr1 in Node A and the LUN is online (from the view in in NetApp System Manager
- View in the VM (the location iSCSI Mapped)
- The iSCSI LUN is presented in the servers
After failover testing by shutdown the node A
- The iSCSI LUN is presented in the servers is missing
Based on my current setup and connection and testing, why the LUN mapped in the server is missing although when check in the NetApp System Manager, the volume and LUN is online able to failover without any issue? I might need the view and advise on the physical connectivity between the NetApp C250 and the Cisco switch that might be the real cause of the LUN missing due the redundancy setup. Appreciate any view on this matter. Thanks
Regards,
Zul
