In a previous blog, I introduced Backup and Restore feature of the Trident 25.02 release that enhances the comprehensive data protection capabilities for VMs on KubeVirt-based platforms. In this blog, I will provide a detailed guide on how to create a backup of a VM and restore it. Additionally, I will demonstrate techniques for creating VM backups using labels on VM resources, which is particularly useful when managing multiple VMs within a single namespace. I will show how to restore a specific VM from a backup using label selectors to ensure only the intended VM is restored.
Prerequisites
Hardware Requirements
Ensure you have bare metal servers available for worker node creation in your OpenShift cluster.
OpenShift Cluster Setup
Install the OpenShift cluster that includes bare metal servers.
OpenShift Virtualization Installation
Install and configure the OpenShift Virtualization operator from the Operator Hub. Once installed, you will see the Virtualization option available in the console, allowing you to create VMs from the UI.
Storage Requirements
Ensure ONTAP storage is available and reachable from the worker nodes of the cluster for provisioning storage using Trident.
Trident Installation and Configuration
Install Trident version 25.02 or later on the OpenShift cluster. Create backend objects and storage classes using Trident to provision storage resources.
Trident Protect Installation
Install Trident Protect 25.02 on the cluster to enable backup and restore functionalities for OpenShift Virtualization VMs.
By following these prerequisites and setup instructions, you will be equipped to leverage the powerful backup and restore features provided by Trident 25.02, ensuring crash-consistent data protection for your VMs in an OpenShift Virtualization environment.
Below, you can see the resources that are already setup as mentioned in the prerequisites.
Create a VM in the namespace “demo” with a root disk and a data disk
The following screen shots show the creation of the VM from the console using the template. The root disk chooses the default storage class automatically, so, verify that the default storage class is set appropriately. In my setup, the default storage class is sc-zonea-san. Ensure that when you create the additional disk, you choose the storage class sc-zonea-san and check the “Apply optimized storage settings” checkbox. This will set the Access modes to RWX and Volume Mode to Block.
Note: Trident supports RWX access mode in Block Volume mode for SAN (iSCSI, NVMe/TCP and FC). (It is the default access mode for NAS). RWX Access mode is required if you need to do Live migration of the VMs at a later point.
List the vm, pods, pvc
Create a secret with appvault credentials and create appvault for trident-protect
# cat appvault-secret.yaml
apiVersion: v1
stringData:
accessKeyID: "<access key of S3>"
secretAccessKey: "<secret access key of S3>"
# you can also provide base 64 encoded values instead of string values
#data:
# base 64 encoded values
# accessKeyID: < base 64 encoded access key>
# secretAccessKey: <base 64 encoded secretAccess key>
kind: Secret
metadata:
namespace: trident-protect
type: Opaque
# cat appvault.yaml
apiVersion: protect.trident.netapp.io/v1
kind: AppVault
metadata:
spec:
providerConfig:
azure:
accountName: ""
bucketName: ""
endpoint: ""
gcp:
bucketName: ""
projectID: ""
s3:
bucketName: trident-protect
endpoint: <lif for S3 access>
secure: "false"
skipCertValidation: "true"
providerCredentials:
accessKeyID:
valueFromSecret:
key: accessKeyID
secretAccessKey:
valueFromSecret:
key: secretAccessKey
providerType: OntapS3
# oc create -f appvault-secret.yaml -n trident-protect
# oc create -f appvault.yaml -n trident-protect
Create an app that includes all resources in the “demo” namespace
The namespace demo has only one VM and so the trident protect app created represents that VM. Later, we will see how to selectively create an app if there is more than one VM in the namespace.
# tp create app demo-vm --namespaces demo -n demo --dry-run > app.yaml
yaml
[root@localhost VM-DataProtection]# cat app.yaml
kind: Application
metadata:
creationTimestamp: null
namespace: demo
spec:
includedNamespaces:
- namespace: demo
# oc create -f app.yaml -n demo
Create backups
Create an On-demand backup
# tp create schedule backup-schedule1 --app demo-vm --appvault ontap-s3-appvault --granularity Hourly --minute 45 --backup-retention 1 -n demo --dry-run>backup-schedule-demo-vm.yaml
schedule.protect.trident.netapp.io/backup-schedule1 created
#cat backup-schedule-demo-vm.yaml
kind: Schedule
metadata:
namespace: demo
spec:
appVaultRef: ontap-s3-appvault
applicationRef: demo-vm
backupRetention: "1"
dayOfMonth: ""
dayOfWeek: ""
enabled: true
granularity: Hourly
hour: ""
minute: "45"
recurrenceRule: ""
snapshotRetention: "0"
status: {}
# oc create -f backup-schedule-demo-vm.yaml -n demo
# tp create backup demo-vm-backup-on-demand --app demo-vm --appvault ontap-s3-appvault -n demo
Backup "demo-vm-backup-on-demand" created.
Create a Schedule for backups
kind: Schedule
metadata:
namespace: demo
spec:
dayOfMonth: ""
dayOfWeek: ""
enabled: true
granularity: Hourly
hour: ""
minute: "45"
recurrenceRule: ""
status: {}
Restore from backup
You can restore the VM to the same namespace or to a different namespace from any of the backups you have created. I am showing you an example for each restore operation.
Now, restore the VM from the backup to the demo namespace.
# tp create bir demo-fedora-restore --backup demo/demo-vm-backup-on-demand -n demo --dry-run>vm-demo-bir.yaml
# cat vm-demo-bir.yaml
kind: BackupInplaceRestore
metadata:
annotations:
protect.trident.netapp.io/max-parallel-restore-jobs: "25"
namespace: demo
spec:
appArchivePath: demo-vm_cc8adc7a-0c28-460b-a32f-0a7b3d353e13/backups/demo-vm-backup-on-demand_f6af3513-9739-480e-88c7-4cca45808a80
resourceFilter: {}
status:
postRestoreExecHooksRunResults: null
state: ""
# oc create -f vm-demo-bir.yaml -n demo
backupinplacerestore.protect.trident.netapp.io/demo-fedora-restore created
Verify that the VM, pods and PVC are created in the same demo namespace.
Restore to different namespace
# tp create br demo2-fedora-restore --backup demo/hourly-4c094-20250312154500 --namespace-mapping demo:demo2 -n demo2 --dry-run>vm-demo2-br.yaml
# cat vm-demo2-br.yaml
kind: BackupRestore
metadata:
annotations:
namespace: demo2
spec:
appArchivePath: demo-vm_cc8adc7a-0c28-460b-a32f-0a7b3d353e13/backups/hourly-4c094-20250312154500_aaa14543-a3fa-41f1-a04c-44b1664d0f81
namespaceMapping:
- destination: demo2
source: demo
resourceFilter: {}
status:
conditions: null
state: ""
# oc create -f vm-demo2-br.yaml -n demo2
In our previous example, we demonstrated backing up a single VM within a namespace. By including the entire namespace in the backup, all resources associated with that VM were captured. But what happens when you have multiple VMs within the same namespace? How can you selectively back up a specific VM and its resources, and then restore it from the correct backup?
Let me show you how.
Create another VM (demo-centos) in the same namespace (demo)
Now label the VM and the related resources for the demo-centos VM.
You can verify that only the demo-centos VM and its PVCs got the labels.
Create an app for only a specific VM (use the label selector)
# tp create app demo-centos-app --namespaces 'demo(category=protect-demo-centos)' -n demo --dry-run>demo-centos-app.yaml
# cat demo-centos-app.yaml
kind: Application
metadata:
namespace: demo
spec:
includedNamespaces:
- labelSelector:
matchLabels:
category: protect-demo-centos
namespace: demo
status:
conditions: null
# oc create -f demo-centos-app.yaml -n demo
application.protect.trident.netapp.io/demo-centos-app created
Create a backup of only a specific VM by using the app (demo-centos-app)
# tp create backup demo-centos-backup-on-demand --app demo-centos-app --appvault ontap-s3-appvault -n demo
Backup "demo-centos-backup-on-demand" created.
Restore from this backup (only demo-centos is restored)
Now, delete the demo-centos VM and restore it from the backup you just created.
[root@localhost VM-DataProtection]# tp create bir demo-centos-restore --backup demo/demo-centos-backup-on-demand -n demo --dry-run>demo-centos-bir.yaml
[root@localhost VM-DataProtection]# cat demo-centos-bir.yaml
metadata:
annotations:
namespace: demo
spec:
appArchivePath: demo-centos-app_a7f2c791-f450-4245-871e-aa33cb4ffbf5/backups/demo-centos-backup-on-demand_e8ff8965-0c37-46ac-966f-97ed378c73f8
resourceFilter: {}
status:
state: ""
[root@localhost VM-DataProtection]# oc create -f demo-centos-bir.yaml -n demo
backupinplacerestore.protect.trident.netapp.io/demo-centos-restore created
Verify that the demo-centos VM and its pvcs have been restored.
Conclusion
In this blog, we've explored how to protect VMs in OpenShift Virtualization using the robust backup and restore capabilities of Trident Protect. You have learned how to create backups and restore VMs, as well as how to use label selectors to selectively backup and restore specific VMs within a namespace. For more detailed information, please refer to the Trident Protect documentation. Additionally, for guidance on Failover and Failback scenarios for OpenShift Virtualization VMs, consult the Solutions documentation.
