- Create Trident back end for source cluster. Start by creating a Trident back end with the storage driver ontap-san. You can do this either by configuring the TridentBackendConfig (TBC) custom resource definition using the Kubernetes-native approach or by using a custom JSON file with tridentctl, a command-line utility for managing Trident. The configuration is similar to any other ontap-san NVMe back end, with the only changes being the username and password. You can either use a cluster management IP with administrator credentials or specify a storage virtual machine with its management IP and credentials. For more information, refer to ONTAP SAN driver details.
# Kubernetes secret required for creating Trident backend from TBC
[root@scs000646264 artifacts]# cat primary-secret.yaml
apiVersion: v1
kind: Secret
metadata:
type: Opaque
stringData:
username: <username>
password: <password>
[root@scs000646264 artifacts]# kubectl create -f primary-secret.yaml -n trident
secret/primary-tbc-secret created
- Add the back end. When the back end is configured, you can add it to Trident by using either kubectl or tridentctl. These tools are a convenient way to add the newly configured back end to Trident and make it available for use.
# Kubernetes CR TridentBackendConfig (TBC)
[root@scs000646264 artifacts]# cat primary-tbc.yaml---
kind: TridentBackendConfig
metadata:
spec:
version: 1
storageDriverName: ontap-san
sanType: nvme
managementLIF: 8.8.8.8
svm: svm0
credentials:
[root@scs000646264 artifacts]# kubectl create -f primary-tbc.yaml -n trident
tridentbackendconfig.trident.netapp.io/primary-backend-tbc created
[root@scs000646264 artifacts]# kubectl get tbc -n trident
NAME BACKEND NAME BACKEND UUID PHASE STATUS
primary-backend-tbc primary-backend-tbc a9b1a3a7-66a8-4d3b-984a-b87d851387c7 Bound Success
# Or, Trident backend json
[root@scs000646264 artifacts]# cat backend.json
"version": 1,
"storageDriverName": "ontap-san",
"managementLIF": "8.8.8.8",
"backendName": "primary-backend"
"svm": "svm0",
"username": "<username>",
"password": "<password>",
"sanType": "nvme"
[root@scs000646264 artifacts]# tridentctl create b -f primary-backend.json -n trident
| NAME | STORAGE DRIVER | UUID | STATE | USER-STATE | VOLUMES |
| primary-backend | ontap-san | 6458337e-a27e-4cde-8707-0f6218214356 | online | normal | 0 |
+--------------------+----------------+--------------------------------------+--------+------------+---------+ - Define a storage class. Create a storage class that corresponds to the type of storage driver you need. This step allows you to define the characteristics of the storage that you want to dynamically provision.
kind: StorageClass
metadata:
parameters:
backendType: ontap-san
storagePools: primary-backend-tbc:.*
allowVolumeExpansion: true
root@scs000646264 artifacts]# kubectl create -f primary-sc.yaml
storageclass.storage.k8s.io/primary-sc created
[root@scs000646264 artifacts]# kubectl get sc
NAME PROVISIONER RECLAIMPOLICY VOLUMEBINDINGMODE ALLOWVOLUMEEXPANSION AGE
primary-sc csi.trident.netapp.io Delete Immediate true 2s
- Create a PVC. Define a PersistentVolumeClaim that specifies the amount of storage you need and references the appropriate storage class. This step ensures that your Kubernetes application has access to the required block storage.
kind: PersistentVolumeClaim
apiVersion: v1
metadata:
spec:
accessModes:
- ReadWriteOnce
resources:
requests:
storage: 20Mi
storageClassName: primary-sc
[root@scs000646264 artifacts]# kubectl create -f primary-pvc.yaml
persistentvolumeclaim/primary-pvc created​ - Confirm PVC binding. After the PVC is created, verify that it’s successfully bound to a persistent volume (PV). This step confirms that the block storage is ready for use by your applications.
[root@scs000646264 artifacts]# kubectl get pvc
NAME STATUS VOLUME CAPACITY ACCESS MODES STORAGECLASS VOLUMEATTRIBUTESCLASS AGE
primary-pvc Bound pvc-bd77f21b-4522-41e9-bfa1-fca7cf8af672 20Mi RWO primary-sc <unset> 4s
- Use the PVC. You’re now ready to use the PVC in any pod of your choice. Mount the PVC in a pod to store data.
The following example simulates an application workload. This pod runs an Nginx container, writing timestamps to a file on the PVC every 20 seconds.
[root@scs000646264 artifacts]# cat pod.yaml
apiVersion: v1
kind: Pod
metadata:
spec:
containers:
- image: nginx:alpine
volumeMounts:
- mountPath: /pv/pvc
command: ["/bin/ash", "-c"]
args:
while true; do
echo `date +%Y-%m-%d.%H:%M:%S` >> /pv/pvc/data.txt;
fsync /pv/pvc;
fsync /pv/pvc/data.txt;
tail -n 1 /pv/pvc/data.txt;
sleep 20;
done
nodeSelector:
kubernetes.io/arch: amd64
kubernetes.io/os: linux
volumes:
- name: local-storage
persistentVolumeClaim:
claimName: primary-pvc
[root@scs000646264 artifacts]# kubectl create -f pod.yaml
pod/source-pod created
[root@scs000646264 artifacts]# kubectl get po
NAME READY STATUS RESTARTS AGE
source-pod 1/1 Running 0 15s
[root@scs000646264 artifacts]# kubectl logs source-pod
2025-05-21.07:30:12
2025-05-21.07:30:32
- Create source MirrorRelationship custom resource (CR) with local information (localPVCName).
Trident fetches the internal information for the volume and the volume’s current data protection (DP) state, then populates the status field of the MirrorRelationship.
kind: TridentMirrorRelationship
metadata:
spec:
state: promoted
volumeMappings:
- localPVCName: primary-pvc
[root@scs000646264 artifacts]# kubectl create -f source-tmr.yaml
tridentmirrorrelationship.trident.netapp.io/source-tmr created
[root@scs000646264 artifacts]# kubectl get tmr
NAME DESIRED STATE LOCAL PVC ACTUAL STATE MESSAGE
source-tmr promoted primary-pvc promoted
- Get the TridentMirrorRelationship CR to obtain the internal name and SVM of the PVC.
[root@scs000646264 artifacts]# kubectl get tmr source-tmr -o yaml
metadata:
creationTimestamp: "2025-05-21T07:26:15Z"
finalizers:
- trident.netapp.io
generation: 2
namespace: default
resourceVersion: "4573176"
uid: 7d0cb8e2-434a-4c1b-b3a8-8d181f744f82
spec:
replicationPolicy: ""
replicationSchedule: ""
state: promoted
volumeMappings:
promotedSnapshotHandle: ""
remoteVolumeHandle: ""
status:
conditions:
- lastTransitionTime: "2025-05-21T07:26:15Z"
localVolumeHandle: svm0:trident_pvc_bd77f21b_4522_41e9_bfa1_fca7cf8af672
message: ""
observedGeneration: 2
state: promoted​ - Perform the following steps for the destination cluster:
Create Trident back end with a replicationPolicy of MirrorAllSnapshots.
[root@scs000646264 artifacts]# cat secondary-secret.yaml
apiVersion: v1
kind: Secret
metadata:
type: Opaque
stringData:
[root@scs000646264 artifacts]# kubectl create -f secondary-secret.yaml -n trident
secret/secondary-tbc-secret created
[root@scs000646264 artifacts]# cat secondary-tbc.yaml
metadata:
spec:
version: 1
sanType: nvme
managementLIF: 7.7.7.7
svm: svm1
replicationPolicy: MirrorAllSnapshots
replicationSchedule: five_minute
credentials:
[root@scs000646264 artifacts]# kubectl create -f secondary-tbc-tamu.yaml -n trident
tridentbackendconfig.trident.netapp.io/secondary-backend-tbc created
secondary-backend-tbc secondary-backend-tbc c4fbde1a-cf6c-4ee4-8474-488454c926d1 Bound Success
"version": 1,
"managementLIF": "7:7:7:7",
"backendName": "secondary-backend"
"svm": "svm0",
"sanType": "nvme"
"replicationPolicy": "MirrorAllSnapshots"
"replicationSchedule": "five_minute"
| secondary-backend | ontap-san | 2345337e-e67e-4bdm-8707-1d5644326548 | online | normal | 0 |
- Create destination storage class.
[root@scs000646264 artifacts]# cat secondary_sc.yaml
apiVersion: storage.k8s.io/v1
kind: StorageClass
metadata:
parameters:
storagePools: secondary-backend-tbc:.*
[root@scs000646264 artifacts]# kubectl create -f secondary_sc.yaml
storageclass.storage.k8s.io/secondary-sc created
primary-sc csi.trident.netapp.io Delete Immediate true 11s
secondary-sc csi.trident.netapp.io Delete Immediate true 3s
- Create destination PVC with previously created StorageClass to act as the secondary (SnapMirror destination).
Trident checks for the TridentMirrorRelationship CRD. If the relationship does not exist, Trident fails to create the volume and remains in pending state until the destination TMR is created.
If the relationship exists, Trident places the new FlexVol volume onto an SVM that is peered with the remote SVM defined in the MirrorRelationship.
[root@scs000646264 artifacts]# cat secondary-pvc.yaml
apiVersion: v1
metadata:
annotations:
trident.netapp.io/mirrorRelationship: dest-tmr
spec:
accessModes:
- ReadWriteOnce
resources:
requests:
storage: 20Mi
storageClassName: secondary-sc
[root@scs000646264 artifacts]# kubectl create -f secondary-pvc.yaml
persistentvolumeclaim/secondary-pvc created
primary-pvc Bound pvc-bd77f21b-4522-41e9-bfa1-fca7cf8af672 20Mi RWO primary-sc <unset> 43s
secondary-pvc Pending secondary-sc <unset> 4s - Create destination TMR CR.
Trident creates a SnapMirror relationship with the configured relationship policy name (or default for ONTAP) and initializes it. (Provide the value obtained in “Get the TridentMirrorRelationship CR to obtain the internal name and SVM of the PVC,” earlier in this document, as the remoteVolumeHandle in destination TMR CR.)
kind: TridentMirrorRelationship”
metadata:
spec:
state: established
volumeMappings:
- localPVCName: secondary-pvc
remoteVolumeHandle: "svm0:trident_pvc_bd77f21b_4522_41e9_bfa1_fca7cf8af672"
[root@scs000646264 artifacts]# kubectl create -f dest-tmr.yaml
tridentmirrorrelationship.trident.netapp.io/dest-tmr created
dest-tmr established secondary-pvc established
Verify the SnapMirror relationship and volume type (DP) on the destination cluster:
stiA300-2491746692774::> snapmirror show
Progress
Source Destination Mirror Relationship Total Last
Path Type Path State Status Progress Healthy Updated
XDP svm1:trident_pvc_32d31b4d_ec91_41cd_a95e_9e74bd6b2d9b
Snapmirrored
Idle - true -
stiA300-2491746692774::> volume show -vserver svm1
Vserver Volume Aggregate State Type Size Available Used%
svm1 svm0_root stiA300_250_aggr1
online RW 1GB 972.4MB 0%
svm1 trident_pvc_32d31b4d_ec91_41cd_a95e_9e74bd6b2d9b
stiA300_249_aggr1
online DP 22MB 20.42MB 7%
2 entries were displayed.
Create snapshot class
[root@scs000646264 artifacts]# cat snapshot-class.yaml
apiVersion: snapshot.storage.k8s.io/v1
kind: VolumeSnapshotClass
metadata:
driver: csi.trident.netapp.io
deletionPolicy: Delete
[root@scs000646264 artifacts]# kubectl create -f snapshot-class.yaml
volumesnapshotclass.snapshot.storage.k8s.io/csi-snapclass created
[root@scs000646264 artifacts]# kubectl get volumesnapshotclasses
NAME DRIVER DELETIONPOLICY AGE
csi-snapclass csi.trident.netapp.io Delete 5s
Below is the output for the snapshot show command in the Destination cluster, Before any snapshot is created.
stiA300-2491746692774::> snapshot show
---Blocks---
Vserver Volume Snapshot Size Total% Used%
snapmirror.33ffbac2-300c-11f0-8dc5-00a098f48d3e_2155208310.2025-05-21_032847
216KB 1% 40%
snapmirror.33ffbac2-300c-11f0-8dc5-00a098f48d3e_2155208310.2025-05-21_033000
136KB 1% 29%
​ - Create snapshot
metadata:
spec:
volumeSnapshotClassName: csi-snapclass
source:
persistentVolumeClaimName: primary-pvc
root@scs000646264 artifacts]# kubectl create -f snapshot.yaml
volumesnapshot.snapshot.storage.k8s.io/snap1 created
[root@scs000646264 artifacts]# kubectl get volumesnapshots
NAME READYTOUSE SOURCEPVC SOURCESNAPSHOTCONTENT RESTORESIZE SNAPSHOTCLASS SNAPSHOTCONTENT CREATIONTIME AGE
snap1 true primary-pvc 20Mi csi-snapclass snapcontent-7a3b0380-6d13-4cb9-88a3-df9528be73a9 5s 6s
Output of the snapshot show command in the destination cluster after the first Snapshot copy is taken:
---Blocks---
216KB 1% 19%
snapshot-7a3b0380-6d13-4cb9-88a3-df9528be73a9
268KB 1% 22%
snapmirror.33ffbac2-300c-11f0-8dc5-00a098f48d3e_2155208310.2025-05-21_033740
180KB 1% 16%
3 entries were displayed.​
Working with more Snapshot copies:
metadata:
spec:
source:
root@scs000646264 artifacts]# kubectl create -f snapshot-1.yaml
volumesnapshot.snapshot.storage.k8s.io/snap1-new created
[root@scs000646264 artifacts]# kubectl get vs
snap1 true primary-pvc 20Mi csi-snapclass snapcontent-7a3b0380-6d13-4cb9-88a3-df9528be73a9 6m33s 6m34s
snap1-new true primary-pvc 20Mi csi-snapclass snapcontent-56cf40dc-f968-4aeb-9ffd-ea1f7bcf0942 4s 5s
Snapshots transfer ensures the replication process.
---Blocks---
268KB 1% 20%
276KB 1% 21%
snapshot-56cf40dc-f968-4aeb-9ffd-ea1f7bcf0942
264KB 1% 20%
snapmirror.33ffbac2-300c-11f0-8dc5-00a098f48d3e_2155208310.2025-05-21_034000
272KB 1% 21%
4 entries were displayed.
In Trident, when the state of the destination TMR is established, it indicates that the destination volume is a Data Protection (DP) volume. DP volumes are used for replication and backup, so that your data is protected and can be recovered in case of failure.
To verify that the destination volume is indeed a DP volume, you can use the volume show command:
stiA300-249
vol0 aggr0_stiA300_249
online RW 348.6GB 291.9GB 11%
stiA300-250
vol0 aggr0_stiA300_250
online RW 348.6GB 291.7GB 11%
stiA300_249_aggr1
online DP 22MB 19.93MB 9%
vs0 root_vs0 stiA300_249_aggr1
online RW 1GB 972.1MB 0%
5 entries were displayed.
