By now, you're probably familiar with Trident, the powerful tool that enables seamless consumption and management of storage resources across all popular NetApp storage platforms. Whether you're working in the public cloud or on-premises, Trident has you covered. It supports a wide range of NetApp storage solutions, including ONTAP clusters (AFF, FAS, and ASA), ONTAP Select, Cloud Volumes ONTAP, Element software (NetApp HCI, SolidFire), Azure NetApp Files, Amazon FSx for NetApp ONTAP, and Google Cloud NetApp Volumes.
Trident is a fully supported, open-source project maintained by NetApp, designed to meet the persistence demands of your containerized applications using industry-standard interfaces like the Container Storage Interface (CSI).
CSI is a standard that allows storage vendors to provide drivers to expose block and file storage systems to containerized workloads on Kubernetes and Kubernetes based platforms. It provides the necessary standards to implement various storage features that Kubernetes leverages to manage persistent storage for containerized workloads.
Trident, being CSI-compliant, integrates natively with Kubernetes and supports dynamic storage orchestration. You might have already used the volume snapshot feature in Kubernetes, which allows you to create point-in-time snapshots of single volumes. This feature relies on the CSI driver to implement specific snapshot capabilities, and Trident leverages the efficient NetApp Snapshot technology.
Did you know that Kubernetes introduced the Volume Group Snapshot as an alpha feature in v1.27 and promoted it to Beta in v1.32? Why is this feature important, and how does Trident support it? Let's explore!
Imagine workloads that span multiple persistent volumes, such as databases where data is stored in one volume and logs in another. To achieve application-consistent snapshots, you typically must quiesce the application, take individual snapshots of each volume, and then unquiesce the application. However, this approach has some drawbacks:
- Sometimes, it may not be possible to quiesce the application.
- Quiescing might be too expensive to perform frequently.
- You might prefer to quiesce the application for weekly backups but not for nightly backups.
- Taking individual snapshots can take longer than taking a snapshot of all volumes simultaneously.
- Restoring an application from individually taken snapshots may not be application-consistent.
Clearly, this method has its limitations. So, what's the solution?
Kubernetes addresses this issue with the Volume Group Snapshot feature, designed for modern container workloads and VMs running as containers. This feature allows you to create crash-consistent snapshots of multiple PersistentVolumeClaims (PVCs) simultaneously. To support this, Kubernetes introduces three new API objects:
- VolumeGroupSnapshotClass: Created by cluster administrators to describe how volume group snapshots should be created.
- VolumeGroupSnapshot: Requested by Kubernetes users to create a volume group snapshot for multiple PVCs.
- VolumeGroupSnapshotContent: Created by the snapshot controller for dynamically created VolumeGroupSnapshots.
Trident 25.06 automatically detects new CRDs (specified for the Volume Group Snapshot feature) to enable the relevant feature gates in the Trident CSI sidecars. So, how do you use these CRDs to create the required Trident objects for Volume Group Snapshots? Let's dive in!
Here is the outline of steps I followed to demonstrate the use of VolumeGroupSnapshotclass to create snapshots of a group of volumes and then restore from the snapshots.
- Install OpenShift Cluster version: 4.19
- OpenShift version 4.19 uses Kubernetes v1.32 where the Volume Group Snapshot feature is elevated to Beta Status.
- Turn the FeatureGate on for VolumeGroupSnapshots.
- Install Trident version 25.06.1 or later.
- Turn the Feature Gate on for VolumeGroupSnapshots.
- Use node-prep for installing iSCSI tools.
- Create a Trident iscsi backend, iscsi storage Class and Volume Snapshot class.
- The Volume Group Snapshot feature is supported by Trident only for iscsi protocol currently.
- Make the Storage class and the Volume Snapshot class defaults in the cluster.
- Create the VolumeGroupSnapshotClass
- Install OpenShift Virtualization Operator.
- Create a VM with 3 disks. (root disk and 2 additional disks)
- Label the PVC(s).
- Create VolumeGroupSnapshots
- Check the Backend ONTAP system
- Restore the disks of the VM
Let me elaborate on each of the above steps:
1. Here is my OpenShift Cluster v4.19 installed with Kubernetes v1.32
# oc get nodes
NAME STATUS ROLES AGE VERSION
master1 Ready control-plane,master 17d v1.32.6
master2 Ready control-plane,master 17d v1.32.6
master3 Ready control-plane,master 17d v1.32.6
worker1 Ready worker 17d v1.32.6
worker2 Ready worker 17d v1.32.6
worker3 Ready worker 17d v1.32.6
I turned the FeatureGate on for VolumeGroupSnapshot by doing the following:
Use the OpenShift web console by navigating to Administration -> Custom Resource Definitions, then searching for and clicking on "FeatureGate". From there, click the "Instances" tab and select the "cluster" instance.
Edit the YAML: Within the YAML tab, edit the FeatureGate/cluster object to include VolumeGroupSnapshot in the enabled list under customNoUpgrade.
apiVersion: config.openshift.io/v1
kind: FeatureGate
metadata:
spec:
featureSet: CustomNoUpgrade
customNoUpgrade:
enabled:
​2. Install Trident 25.06.1 using node-prep for installing iSCSI tools.
# tridentctl install -n trident --node-prep iscsi
Ensure that the required CRDs for VolumeGroupSnapshots are installed
[root@localhost trident-installer]# kubectl get crd | grep "volumegroupsnapshot"
volumegroupsnapshotclasses.groupsnapshot.storage.k8s.io 2025-08-12T16:12:46Z
volumegroupsnapshotcontents.groupsnapshot.storage.k8s.io 2025-08-12T16:12:46Z
volumegroupsnapshots.groupsnapshot.storage.k8s.io 2025-08-12T16:12:46Z
3. Create the backend and the storage classes for iSCSI protocol and create a VolumeSnapshotClass Object with the following yaml definitions.
# cat tbc-iscsi.yaml
apiVersion: v1
kind: Secret
metadata:
type: Opaque
stringData:
username: admin
password: <passwd to log into ONTAP ClI>
kind: TridentBackendConfig
metadata:
spec:
version: 1
storageDriverName: ontap-san
managementLIF: <mgmt-lif>
backendName: tbc-iscsi
svm: openshift
storagePrefix: openshift-iscsi
defaults:
formatOptions: "-E nodiscard"
nameTemplate: "{{ .config.StoragePrefix }}_{{ .volume.Namespace }}_{{ .volume.RequestName }}"
credentials:
​# cat sc-iscsi.yaml
apiVersion: storage.k8s.io/v1
kind: StorageClass
metadata:
parameters:
backendType: "ontap-san"
provisioningType: "thin"
fsType: ext4
snapshots: "true"
reclaimPolicy: "Delete"
allowVolumeExpansion: true
#cat snapshotclass.yaml
apiVersion: snapshot.storage.k8s.io/v1
kind: VolumeSnapshotClass
metadata:
driver: csi.trident.netapp.io
deletionPolicy: Retain
[root@localhost volumeGroups]# oc get sc
NAME PROVISIONER RECLAIMPOLICY VOLUMEBINDINGMODE ALLOWVOLUMEEXPANSION AGE
sc-iscsi (default) csi.trident.netapp.io Delete Immediate true 2d22h
thin-csi csi.vsphere.vmware.com Delete WaitForFirstConsumer true 18d
[root@localhost volumeGroups]# oc get volumesnapshotclass
NAME DRIVER DELETIONPOLICY AGE
csi-vsphere-vsc csi.vsphere.vmware.com Delete 18d
trident-snapshotclass csi.trident.netapp.io Delete 2d22h
4. Set the storage class and the volumesnapshotclass as defaults.
kubectl patch storageclass <storage-class-name> -p '{"metadata": {"annotations":{"storageclass.kubernetes.io/is-default-class":"true"}}}'kubectl patch volumesnapshotclass <volumesnapshotclass-name> --type=merge -p '{"metadata":{"annotations":{"snapshot.storage.kubernetes.io/is-default-class":"true"}}}'Note: It is best practice to have both trident storage class and snapshot class set as default so that you take advantage of fast FlexCloning mechanism from snapshots of the golden image when creating new VMs.
5. Create VolumeGroupSnapshot class
# cat volumegroupsnapshotclass.yaml
apiVersion: groupsnapshot.storage.k8s.io/v1beta1
kind: VolumeGroupSnapshotClass
metadata:
annotations:
kubernetes.io/description: "Trident group snapshot class"
deletionPolicy: Delete
# oc get volumegroupsnapshotclass
trident-groupsnapshotclass csi.trident.netapp.io Delete 2d22h
6. After installing OpenShift Virtualization, you can verify that the golden images are available in volume snapshots.
7. Now create a VM using the default template. Create 2 additional disks using the default storage class for this VM.
# oc get vm
NAME AGE STATUS READY
fedora-vm1 62s Running True
# oc get pvc
NAME STATUS VOLUME CAPACITY ACCESS MODES STORAGECLASS VOLUMEATTRIBUTESCLASS
dv-fedora-vm1-disk1-ulsgg2 Bound pvc-6cfe08d6-6910-44ed-b671-1d23e9cf04d1 10Gi RWX sc-iscsi <unset>
dv-fedora-vm1-disk2-86oq76 Bound pvc-619bb1b5-6e1a-4193-ab04-4e16361fe699 20Gi RWX sc-iscsi <unset>
fedora-vm1 Bound pvc-5e278dc3-79b3-47be-85c1-1b84acb151ec 30Gi RWX sc-iscsi <unset>
You can check the corresponding volumes in ONTAP backend.
The root disk volume is a flex-clone volume of the snapshot with the golden image.
The other 2 volumes for the 2 disks of the VMs are FlexVol volumes.
I logged into the VM using virtctl tool and formatted and mounted the 2 disks as shown below:
fedora-vm1 login: fedora
Password:
[fedora@fedora-vm1 ~]$ sudo mkfs.ext4 /dev/vdc
[fedora@fedora-vm1 ~]$ sudo mkfs.ext4 /dev/vdd
[fedora@fedora-vm1 ~]$ sudo mount /dev/vdc /mnt/data1
[fedora@fedora-vm1 ~]$ sudo mount /dev/vdd /mnt/data2
[fedora@fedora-vm1 ~]$ lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
zram0 251:0 0 1.8G 0 disk [SWAP]
vda 253:0 0 30G 0 disk
├─vda1 253:1 0 2M 0 part
├─vda2 253:2 0 100M 0 part /boot/efi
├─vda3 253:3 0 1000M 0 part /boot
└─vda4 253:4 0 28.9G 0 part /var
/home
vdb 253:16 0 1M 0 disk
vdc 253:32 0 10G 0 disk /mnt/data1
vdd 253:48 0 20G 0 disk /mnt/data2
I have created a file called sample.txt in each of the disks.
[fedora@fedora-vm1 data1]$ pwd
/mnt/data1
[fedora@fedora-vm1 data1]$ ls
lost+found sample.txt
[fedora@fedora-vm1 data2]$ pwd
/mnt/data2
[fedora@fedora-vm1 data2]$ ls
8. Now label each pvc of the VM using the same key/value.
#oc label pvc fedora-vm1 consistencygroup=group1
persistentvolumeclaim/fedora-vm1 labeled
# oc label pvc dv-fedora-vm1-disk1-ulsgg2 consistencygroup=group1
persistentvolumeclaim/dv-fedora-vm1-disk1-ulsgg2 labeled
# oc label pvc dv-fedora-vm1-disk2-86oq76 consistencygroup=group1
persistentvolumeclaim/dv-fedora-vm1-disk2-86oq76 labeled
Check the labels of the PVCs
[root@localhost volumeGroups]# oc get pvc fedora-vm1 -o jsonpath='{.metadata.labels.consistencygroup'}
group1
[root@localhost volumeGroups]# oc get pvc dv-fedora-vm1-disk1-ulsgg2 -o jsonpath='{.metadata.labels.consistencygroup'}
group1
[root@localhost volumeGroups]# oc get pvc dv-fedora-vm1-disk2-86oq76 -o jsonpath='{.metadata.labels.consistencygroup'}
group1
9. Now let us create a volumeGroupSnapshot using the following yaml.
# cat vgs.yaml
metadata:
spec:
volumeGroupSnapshotClassName: trident-groupsnapshotclass
source:
selector:
matchLabels:
consistencygroup: group1
# oc create -f vgs1.yaml
volumegroupsnapshot.groupsnapshot.storage.k8s.io/vgs1 created
# oc get vgs/vgs1
NAME READYTOUSE VOLUMEGROUPSNAPSHOTCLASS VOLUMEGROUPSNAPSHOTCONTENT CREATIONTIME AGE
vgs1 true trident-groupsnapshotclass groupsnapcontent-82e42f0f-d421-4743-bbaf-f56ee56241d1 2m9s 2m26s
# oc get volumesnapshots
NAME READYTOUSE SOURCEPVC RESTORESIZE
snapshot-4d47c9f45423bfca625a0f1b6c5a5ec456ac59d3e583157be919bb7237317c65 true dv-fedora-vm1-disk1-ulsgg2 10Gi
snapshot-61c1aada41e28c4fd68327ad10b5561657ed4c7d391d1547569a47204f5f92b9 true fedora-vm1 30Gi
snapshot-afb4c4833460e233c4e86f1108c921b86a6f4d0eb182e99e579081ff6f743f56 true dv-fedora-vm1-disk2-86oq76 20Gi
A snapshot of all the pvcs with the label key/value pair consistencygroup: group1 will be created. Trident VolumeGroupSnapshots uses ONTAP consistency group in the ONTAP backend.
Note: Trident VolumeGroupSnapshots uses ONTAP consistency group(CG) in the ONTAP backend. If you use REST API, a CG is created with all the volumes belonging to the VM (as grouped by the labels), a snapshot of each volume is taken in a consistent way, and then the CG is deleted. You may or may not be able to see the consistency Group being created and deleted in ONTAP, depending on the timing. Here, I have captured the consistency group created and then deleted in ONTAP.
HCG-NetApp-C400-E9U9::> consistency-group show -vserver openshift
(vserver consistency-group show)
Parent
Consistency Consistency
Vserver Group Group State Size Available Used
openshift cg-snapshot-82e42f0f-d421-4743
- online 22GB 21.99GB 7.46MB
There are no entries matching your query.
RESTORING the PVCs of the VM from individual snapshots using Trident
Now let us assume that we have lost the sample.txt file from each of the 2 data disks.
/mnt/data1
lost+found
/mnt/data2
lost+found
Note: Although we created a snapshot of a group of volumes as a single unit, we can only restore from individual snapshot.
We all know how to restore a volume from its snapshot using ONTAP CLI or the System Manager. But can we do a volume restoration from its snapshot using Trident? Yes, of course and let us see how.
Trident provides rapid, in-place volume restoration from a snapshot using the TridentActionSnapshotRestore (TASR) CR. This CR functions as an imperative Kubernetes action and does not persist after the operation completes.
First, stop the VM.
Now let's restore the content of the first disk/PVC with its corresponding snapshot using the yaml as shown below:
# cat tasr1.yaml
kind: TridentActionSnapshotRestore
metadata:
namespace: default
spec:
pvcName: dv-fedora-vm1-disk1-ulsgg2
volumeSnapshotName: snapshot-4d47c9f45423bfca625a0f1b6c5a5ec456ac59d3e583157be919bb7237317c65
# oc create -f tasr1.yaml
tridentactionsnapshotrestore.trident.netapp.io/trident-snap created
Similarly, create another TASR object for the second disk using the PVC and its corresponding snapshot.
# cat tasr2.yaml
metadata:
namespace: default
spec:
pvcName: dv-fedora-vm1-disk2-86oq76
volumeSnapshotName: snapshot-afb4c4833460e233c4e86f1108c921b86a6f4d0eb182e99e579081ff6f743f56
# oc create -f tasr2.yaml
Let us make sure that the restore operation is showing succeeded state.
[root@localhost volumeGroups]# oc get tasr
NAME NAMESPACE PVC SNAPSHOT STATE
trident-snap-disk1 default dv-fedora-vm1-disk1-ulsgg2 snapshot-4d47c9f45423bfca625a0f1b6c5a5ec456ac59d3e583157be919bb7237317c65 Succeeded
trident-snap-disk2 default dv-fedora-vm1-disk2-86oq76 snapshot-afb4c4833460e233c4e86f1108c921b86a6f4d0eb182e99e579081ff6f743f56 Succeeded
Now let us start the VM, login to it and ensure that the sample.txt file is back on the disks.
[fedora@fedora-vm1 ~]$ ls /mnt/data1
[fedora@fedora-vm1 ~]$ ls /mnt/data2
Conclusion
In this blog, I have demonstrated how to create a volume group snapshot of all the PVCs of a VM in OpenShift Virtualization as a single unit and how to restore each snapshot individually using the TridentActionSnapShotRestore CR. This powerful feature ensures that your application data remains consistent and easily manageable, even across multiple volumes.
If you're interested in learning how to use the Volume Group Snapshot feature for container workloads on vanilla Kubernetes, I highly recommend checking out the lab scenario written by Yves Weisser. It's an excellent resource for understanding the application of this feature in different environments.
For more detailed information and comprehensive guides, please visit the Trident documentation page on working with volume group snapshots.
