If you’re looking for a New Year’s resolution that you can keep, we have you covered! If you didn’t know, NetApp has been a certified provider of Ansible modules since Red Hat first offered certification. While many are familiar with the ONTAP modules in Ansible, there are also powerful modules available for StorageGRID!
The NetApp team recently released a new Ansible collection,version 21.16.0, for StorageGRID. Whether you’re new to automation or need to automate your StorageGRID environment, now is a perfect time to start using these modules or expand your use of automation. For those new to these modules, here's an example along with explanations of the options you can use to further your automation journey.
Onboarding a New Tenant
A typical workflow involves onboarding a new tenant. This could be a department in your company, a customer if you are a service provider, or simply a way to demarcate access. Adding a tenant involves:
- Providing a name for the tenant.
- Setting a password for its root account.
- Creating a bucket to store objects.
- Creating a group to hold users.
- Adding a user to the group.
- Generating an access key pair for the user and displaying it for their records.
We can accomplish all these tasks with a single Ansible playbook. A playbook is a collection of tasks for Ansible to run, written in the YAML format. Here’s what such a playbook might look like:
- name: Onboarding
hosts: localhost
gather_facts: false
vars:
grid_user: root
grid_password: mypassword
grid_address: https://1.2.3.4
t_default_pass: tenant_default
tasks:
- name: generate auth token for grid module on StorageGRID
netapp.storagegrid.na_sg_grid_login:
hostname: "{{ grid_address }}"
username: "{{ grid_user }}"
password: "{{ grid_password }}"
validate_certs: false
register: auth
- name: create a tenant account
netapp.storagegrid.na_sg_grid_tenant:
state: present
api_url: "{{ grid_address }}"
auth_token: "{{ auth.na_sa_token }}"
protocol: "s3"
management: true
allow_platform_services: false
use_own_identity_source: false
tenant_password: "{{ t_default_pass }}"
register: tenant
- name: generate auth token for grid modules on new tenant
tenant_id: "{{tenant.resp.id }}"
register: auth1
- name: create a s3 bucket
netapp.storagegrid.na_sg_org_container:
state: present
auth_token: "{{ auth1.na_sa_token }}"
- name: create a group
netapp.storagegrid.na_sg_org_group:
state: present
display_name: users
unique_name: group/users
management_policy:
manage_all_containers: false
manage_endpoints: false
manage_own_s3_credentials: false
root_access: false
s3_console: false
view_all_containers: false
s3_policy: {"Statement":[{"Effect":"Allow", "Action":"s3:*", "Resource":"arn:aws:s3:::*"}]}
- name: create a tenant user
netapp.storagegrid.na_sg_org_user:
state: present
full_name: user1
unique_name: user/user1
member_of: "group/users"
disable: false
- name: create a s3 key
netapp.storagegrid.na_sg_org_user_s3_key:
state: present
unique_user_name: user/user1
register: key
- name: report s3 key
debug:
msg: "{{ key.resp.accessKey }} : {{ key.resp.secretAccessKey }}"
Breaking It Down
An Ansible playbook starts by giving the “play” a name. A play is a collection of tasks aimed at a single system or group of systems. You can have multiple plays per playbook. This playbook only has one play:
- name: Onboard Tenant
hosts: localhost
gather_facts: false
---: Indicates the start of the YAML file.
- - name: Onboard Tenant: Names our play. This name can be anything.
- hosts: localhost: Specifies that the tasks will run on the localhost.
- gather_facts: false: Saves time by not collecting information about the localhost, as it’s not relevant to our StorageGRID work.
Variables Section
vars:
grid_user: root
This section defines variables that will be used throughout the playbook. The keys can be anything meaningful to you and future maintainers.
Using Variables with {{ }}
In Ansible, variables are used to store values that can be reused throughout your playbook. They help make your playbook more flexible and easier to maintain. Variables are referenced using the {{ }} syntax, which tells Ansible to replace the placeholder with the actual value of the variable.
Here’s an example task that uses variables:
- name: Generate auth token for grid module on StorageGRID
register: auth
- hostname: "{{ grid_address }}": The {{ grid_address }} syntax tells Ansible to replace this with the value of the grid_address variable defined in the vars section.
- username: "{{ grid_user }}": Similarly, this will be replaced with the value of grid_user.
- Register: auth: This saves the output of the task so that information can be used later.
Important Points about Using Variables:
- Consistency: Ensure that the variable names used within {{ }} match exactly with those defined in the vars section.
- No Extra Spaces: Be careful with spaces. “{{ grid_address }}” is correct, but “ {{ grid_address }} has an extra space before the variable which may cause issues.
- Quotes and Braces: Variables are typically used within double quotes to ensure proper parsing, especially when dealing with strings.
Example of a Task Using Registered Variables
- name: Create a tenant account
state: present
protocol: "s3"
management: true
register: tenant
- api_url: "{{ grid_address }}": Uses the grid_address variable.
- auth_token: "{{ auth.na_sa_token }}": Uses the auth.na_sa_token variable, which was registered from the output of a previous task.
By using variables, you can easily change values in one place (the vars section) without needing to update every occurrence throughout your playbook. This makes your playbook more maintainable and adaptable to different environments or configurations.
As you can see by linking different modules together you can create a full workflow that can quickly achieve desired results. Ansible can be installed on any Linux system or used with the Red Hat Ansible Automation Platform. The StorageGRID modules are certified and therefore part of both the free Ansible Galaxy module set and the Ansible Automation Platform set.
Check Ansible Galaxy - netapp.storagegrid for full documentation on all the modules available for StorageGRID and leave a comment on how you’re keeping up with your New Year’s resolution of automating StorageGRID with Ansible.
