Move iSCSI Volumes Live with Trident 26.06: A Hands-on Guide to Volume Move
Overview
Kubernetes environments change constantly: aggregates fill, nodes need maintenance, and performance hot spots appear. With Trident 26.06, you can now move an iSCSI-backed volume non-disruptively to a different ONTAP node and aggregate within the same ONTAP cluster—while the application keeps running.
This post shows how to use Volume Move end-to-end and how to monitor it as it progresses.
What Volume Move is (and what it isn’t)
Volume Move is a Trident-orchestrated operation that relocates the ONTAP backing storage for a Kubernetes PV to a new aggregate within the same ONTAP cluster
Trident configures and manages iSCSI multipath connectivity on Kubernetes nodes to support non-disruptive ONTAP volume moves. Trident leverages ONTAP’s built-in volume-move operations to rebalance volumes within an ONTAP cluster.
Scope:
Supported: ontap-san driver, iSCSI volumes, using the ONTAP REST API
- Not supported (for this feature):
- NAS
- FCP
- NVMe
- ontap-san-economy iSCSI driver
Not a cluster-to-cluster migration: this is within one ONTAP cluster
Requirements checklist
Before you try it, confirm:
Trident version: 26.06+
- Backend driver + protocol:
ontap-san with iSCSI, using the ONTAP REST API - ONTAP cluster topology: at least two ONTAP nodes
- If moving across ONTAP HA pairs (more than two nodes), customers must initiate the move using Trident volume-move to keep Kubernetes I/O non-disruptive. Trident coordinates the host-side iSCSI/multipath path updates while ONTAP performs the underlying volume move.
- Credentials / ONTAP version:
- ONTAP 9.19.1 or later if using a dedicated Trident role in ONTAP
- ONTAP 9.19.1 adjusted existing roles in ONTAP. No new roles were required by Trident. If you're already using a Trident role, it should also work for volume-move with ONTAP 9.19.1.
- Find documentation on creating and using a dedicated Trident role in ONTAP here:
- On earlier ONTAP releases, cluster-admin credentials are required for volume-move.
What’s supported (operational notes)
A few practical points that help set expectations in production:
Access modes: ReadWriteOnce (RWO) and ReadWriteMany (RWX) volumes are supported.
Workloads can change during the move: volumes can be attached or detached while a move is in progress (pods being created, rescheduled, moved, or removed by Kubernetes). Trident reconciles attachments throughout; if a node attaches mid-move, it will be brought onto the correct path set automatically.
Moving duration varies by size: the Moving phase can range from minutes for small volumes to multiple hours for very large volumes.
How it works (why it’s non-disruptive)
Trident keeps I/O online by managing connectivity first:
Adds new iSCSI paths to the target location alongside the existing source paths
Lets ONTAP move/cut over the data in-cluster (this is typically the longest phase)
Gracefully removes stale paths post-cutover
From the host’s perspective, the multipath device retains access throughout. Trident will not start the move until all new paths are successfully added.
Hands-on: moving a volume
Step 1: Identify the PV and ONTAP source/target locations
In this step, you’ll identify:
The PV name to move (you’ll use this later in the tridentctl create volume-move command)
The volume’s current ONTAP aggregate (--source-pool)
The node/HA pair that aggregate belongs to (--source-node)
A target node + aggregate to move to and optionally on a different HA pair (--target-node, --target-pool)
1) Identify HA pairs in the cluster
If your goal is to move a volume to a different HA pair, start by confirming which nodes are paired:
> storage failover show
Takeover
by
Node Partner Possible State Description
node-1
node-2 true Connected to node-2
node-2
node-1 true Connected to node-1
node-3
node-4 true Connected to node-4
node-4
node-3 true Connected to node-3
4 entries were displayed.​
From this output, you can see two HA pairs:
2) Find the volume’s current (source) aggregate
Next, determine where the ONTAP volume that backs your PV currently lives.
Run:
volume show -vserver <SVM> -volume <vol-name> -fields aggregate
</code></span>Example:</p><pre class="lia-code-sample language-markup"><code>> volume show -vserver vs0 -volume trident_pvc_60be4d54_ddb1_4e51_bdef_b0bd6c0b80cc -fields aggregate
vserver volume aggregate
vs0 trident_pvc_60be4d54_ddb1_4e51_bdef_b0bd6c0b80cc node_3_aggr1In this example, the source aggregate is node_3_aggr1.
3) Map that aggregate to the source node (and list candidate targets)
List available aggregates and see which node owns each one:
> storage aggregate show -fields node
aggregate node
aggr0_node_1 node-1
aggr0_node_2 node-2
aggr0_node_3 node-3
aggr0_node_4 node-4
node_1_aggr1 node-1
node_2_aggr1 node-2
node_3_aggr1 node-3
node_4_aggr1 node-4
8 entries were displayed.
From this output, you can map the current aggregate to the current node:
4) Select the destination (target) on a different HA pair
Continuing the example:
The volume is currently on node_3_aggr1 (node node-3) → HA Pair B
To move it to the other HA pair (HA Pair A), choose a target on either:
node node-1, or
node node-2
Good target options:
or
5) Final mapping: the exact values you’ll pass to Trident
Using the example above, you now have both source and target values.
Source (current location):
Target (new location), choose one:
Step 2: Start the move
You can start a move either with tridentctl or by applying a TridentVolumeMove custom resource directly. Both approaches create the same move request in Trident.
Option A: Start the move using tridentctl
This command creates a TridentVolumeMove (tvm) CR under the hood (resource name = PV name):
tridentctl create volume-move \
--volume pvc-8a814d62-bd58-4253-b0d1-82f2885db671 \
--source-node node-3 \
--source-pool node_3_aggr1 \
--target-node node-1 \
--target-pool node_1_aggr1 \
-n <Trident Namespace>
Notes:
tvm is a shorthand alias for volume-move
To automatically remove the resource after success, you can add --delete-after-success <DURATION>
Field meanings (quick reference):
sourceNode / targetNode: ONTAP node names (not UUIDs)
sourcePool / targetPool: ONTAP aggregate names
deleteAfterSuccess: optional, takes a duration (e.g. 30s, 10m)
Option B: Start the move by applying a TridentVolumeMove CR
Create a manifest (for example, volume-move.yaml).
The resource name must match the PV name and be created in Trident’s namespace:
kind: TridentVolumeMove
metadata:
namespace: trident
spec:
sourceNode: node-3
sourcePool: node_3_aggr1
targetNode: node-1
targetPool: node_1_aggr1
# Optional: delete the CR after success. Use a duration like 10m, 30s, etc.
# Set to 0 to delete immediately, or omit the option to retain.
# deleteAfterSuccess: 10m
Apply it:
kubectl apply -f volume-move.yaml
Monitor the move
Watch overall progress:
kubectl get tridentvolumemove -n trident
NAMESPACE NAME VOLUME STATE AGE
trident pvc-8a814d62-bd58-4253-b0d1-82f2885db671 pvc-8a814d62-bd58-4253-b0d1-82f2885db671 Moving 22s
Inspect state + per-node progress:
kubectl describe tridentvolumemove <pv-name> -n trident
apiVersion: v1
items:
- apiVersion: trident.netapp.io/v1
metadata:
annotations:
kubectl.kubernetes.io/last-applied-configuration: |
{"apiVersion":"trident.netapp.io/v1","kind":"TridentVolumeMove","metadata":{"annotations":{},"name":"pvc-8a814d62-bd58-4253-b0d1-82f2885db671","namespace":"trident"},"spec":{"sourceNode":"sti249-vsim-ocvs083o","sourcePool":"sti249_vsim_ocvs083o_aggr1","targetNode":"sti249-vsim-ocvs083m","targetPool":"sti249_vsim_ocvs083m_aggr1"}}
creationTimestamp: "2026-08-06T23:17:36Z"
generation: 1
namespace: trident
resourceVersion: "6646309"
uid: 75e39cfb-e931-43fe-8c81-52deeaa902e0
spec:
sourceNode: sti249-vsim-ocvs083o
sourcePool: sti249_vsim_ocvs083o_aggr1
targetNode: sti249-vsim-ocvs083m
targetPool: sti249_vsim_ocvs083m_aggr1
status:
- message: Successfully migrated attachment
node: node-3
state: Migrated
node: node-4
state: Migrated
backendContext:
backendName: my-san-backend
jobEndTime: "2026-08-06T23:18:00Z"
jobID: 1090090f-91ed-11f1-b978-005056bde1aa
jobStartTime: "2026-08-06T23:17:59Z"
jobState: success
svmName: vs0
completionTime: "2026-08-06T23:18:01Z"
initialAccessInfo:
iscsiIgroup: ubuntu-gnu-linux-24-04-3-97290b33-e8d4-43a0-a18c-40271993882c
iscsiLunSerial: x0MKz$/RWjxq
iscsiPortals:
- 10.196.66.157
iscsiTargetIqn: iqn.1992-08.com.netapp:sn.ea2352e380a011f1b978005056bde1aa:vs.5
iscsiTargetPortal: 10.196.66.149
publishEnforcement: true
useCHAP: false
startTime: "2026-08-06T23:17:37Z"
state: Succeeded
targetAccessInfo:
iscsiPortals:
- 10.196.66.141
iscsiTargetPortal: 10.196.66.133
useCHAP: false
What to expect while it runs:
- The Moving state duration can vary widely—from minutes (or less) for small volumes to hours for very large volumes.
- Because the Moving phase can take time, Trident continues to handle attachment changes during the move. Pods can be created, rescheduled, or deleted, and Trident will add or remove the relevant host-side iSCSI paths as nodes attach to or detach from the volume.
- Node errors will reported in the 'message' fields
. status.attachments[].message. - Controller errors will be reported in the 'message' field
.status.message.
Understanding the state machine (so you know what “normal” looks like)
You’ll see the move progress through these states:
Pending: request accepted, validated, info gathered (no storage changes yet)
ControllerStaging: Trident prepares new ONTAP LUN mappings (SLM) for the new location
NodeStaging: Trident adds target paths on each attached node (I/O continues across both path sets)
Moving: ONTAP copies and cuts over data to the target aggregate (Trident polls)
ControllerUnstaging: Trident removes old ONTAP LUN mappings
NodeUnstaging: stale source paths removed on hosts; only target paths remain
Succeeded: move completed successfully
Failed: move failed, see CR status.message for info
Attachment progress: .status.attachments
Each attached Kubernetes node has its own progress state:
Pending → Bridged → Migrated → Cleaned
Plus:
Detached (node detached mid-move; excluded while Trident evaluates readiness)
Failed (terminal node-level error) - see the message field for the failed attachment for info
.status.attachments tracks nodes that were attached when the move entered NodeStaging; new attachments after that may not be listed.
Cleanup and retries
If you set deleteAfterSuccess, Trident removes the TridentVolumeMove resource automatically. Otherwise, it can be deleted manually.
Important retry rule: before requesting another move for the same volume, ensure there is no existing TridentVolumeMove for that PV in Succeeded or Failed state.
Also by design:
Trident never auto-deletes Failed moves (it keeps them as an audit record)
To retry: fix the root cause, delete the Failed resource, then create a new move request
Where this fits operationally
If you’re a Kubernetes admin running Trident with ONTAP SAN (iSCSI), Volume Move gives you a practical new tool to rebalance storage placement, prepare for maintenance, and respond to capacity/performance shifts—without asking app teams for downtime.
See documentation for more information: Move a volume.
