Amazon FSx for NetApp ONTAP is a common data infrastructure choice for many organizations that need to operate workloads on AWS, whether they’re migrating from on-premises, modernizing existing cloud workloads, or building new cloud-based applications.
FSx for ONTAP offers two architectural options: First-generation (Gen 1) and second-generation (Gen 2). Both provide the core ONTAP enterprise capabilities, but their underlying architectures are optimized to support different workload patterns.
Selecting an FSx for ONTAP generation is an architectural decision, not just a feature choice. You should consider workload requirements, growth expectations, recovery goals, regional availability, and operational realities. And, because moving between generations isn’t an in-place change (it requires deployment of a new file system and subsequent migration), this decision needs to be made upfront.
This post explains how Gen 1 and Gen 2 differ, where Gen 1 is still a practical choice for most customers, and when Gen 2 deserves a closer look.
High-availability pairs: The foundation for FSx for ONTAP
FSx for ONTAP is a fully managed AWS service that brings ONTAP capabilities to enterprise workloads in AWS. A key architectural foundation of FSx for ONTAP is the use of high-availability (HA) pairs: two file servers in an active-standby configuration. The active file server processes client and application requests, while file-modifying operations are mirrored to the standby file server, so it can take over if needed.
Each HA pair contributes its own throughput, SSD IOPS, and SSD storage capacity to the file system. HA pairs can be deployed in a single Availability Zone (AZ) or across multi-AZ file systems, depending on workload availability and resilience requirements. The number of HA pairs a file system can support is one of the key differences between FSx for ONTAP generations.
The difference between FSx for ONTAP Gen 1 and Gen 2
The generation selected at deployment determines the underlying HA-pair file system architecture, the performance ceiling, and how provisioned SSD capacity grows over time.
- Gen 1 file systems are powered by a single HA pair, and can scale up to 4 GBps of throughput, 160,000 SSD IOPS, and 192 TiB of SSD storage.
- Gen 2 file systems deliver up to 6 GBps of throughput and 200,000 SSD IOPS per HA pair. In this generation, multi-AZ file systems scale up using a single HA pair, while single-AZ file systems can scale out to as many as 12 HA pairs. Each additional HA pair adds additional throughput and IOPS while keeping access within a single file system namespace. At maximum scale, a Gen 2 single-AZ file system can deliver up to 72 GBps of throughput, 2.4 million SSD IOPS, and 1 PiB of SSD storage. A few design points are worth keeping in mind:
- Gen 2 isn’t available in every AWS Region.
- Gen 2 scale-out only supports a single AZ, even if the file system requires multiple AZs.
- After a file system has been created, you can't change its deployment type (whether multi-AZ or single-AZ), switch it between Gen 1 and Gen 2, or reduce the HA pair count in Gen 2.
- The provisioned capacity limits for both generations refer to SSD storage. FSx for ONTAP can tier infrequently accessed data to a lower-cost capacity pool, which is effectively unlimited, helping organizations manage larger datasets without keeping all data on SSD.
Gen 1: The right architecture for most customers
Gen 1 is a good fit for most workloads where the capacity and performance remain within one HA pair, and where the long-term requirement is an ONTAP environment in AWS with predictable throughput, capacity, and growth. Common applications include enterprise file services, departmental shares, user home directories, application data, and other workloads in which demand is steady rather than highly elastic.
Regional availability might also favor Gen 1. Although AWS continues to expand support for Gen 2, at the time of writing Gen 2 isn't yet available in every AWS Region that supports Gen 1.
When Gen 2 is worth the extra scale
It’s worth evaluating FSx for ONTAP Gen 2 when scale, variability, or anticipated growth might exceed what a single HA pair can support. Examples include electronic design automation, visual effects rendering, big data analytics, AI/ML training, petabyte-scale databases, HPC, and other environments with substantial and unpredictable bursts of parallel activity.
Not every workload in these categories requires Gen 2 performance and scale. The key question is whether the environment requires additional scalability, performance headroom, or room for future growth. If rapid growth or sustained concurrency is expected, Gen 2 offers greater flexibility for long-term planning.
Gen 2 also introduces exclusive features that may influence the architecture decision:
- NVMe/TCP support: Useful for some block-based workloads, particularly where lower-latency access is important.
- Decrease SSD capacity (SSD shrink): Historically, reducing SSD capacity involved risky, disruptive manual migration or total system rebuilds. Gen 2 enables the reduction of SSD capacity (shrinking), so organizations can dynamically right-size storage post-deployment, without impacting application or data availability. This eliminates the need to overprovision for cyclical workloads, resulting in a drastically lower TCO. You can learn more about this feature in our SSD shrink announcement
- Faster access to data restored from backups: Gen 2 letsorganizations begin accessing data from backups while the recovery process is still running in the background, significantly reducing recovery times.
FSx for ONTAP Gen 2 case study: An EDA company with resource-intensive development cycles
In industries such as microchip design and media and entertainment, workloads can experience massive temporary storage and performance requirement peaks. These might exceed the performance delivered by a single HA pair but disappear when the project phase is complete.
In a recent use case, a semiconductor manufacturer was running increasingly complex chip design projects that created sharp spikes in simulation demand. The company needed storage that could scale to support peak design runs without leaving expensive resources idle afterwards.
With FSx for ONTAP, the team could use a scale-out architecture to add performance headroom for high-IOPS, low-latency workloads across four AWS Regions, while adjusting provisioned SSD capacity as project requirements changed. This helped support faster design cycles, keeping data available, and avoiding the need for manual migration to a smaller environment just to reduce storage costs.
Cost and complexity considerations
A common question when evaluating Gen 2 is whether it’s always more expensive than Gen 1. In practice, the answer depends on how the workload behaves.
Workloads that require multiple HA pairs will likely consume substantially more performance infrastructure and may therefore incur a higher storage cost.
However, Gen 2 can often be more cost-efficient for a specific use case because it delivers more performance per file system. If a workload requires very large capacity, high throughput, high IOPS, or substantial room for growth, Gen 2 might avoid overprovisioning and improve infrastructure utilization, which can positively influence TCO over time.
The key consideration is how well the deployment model matches the workload—not whether one option is inherently more or less expensive.
From an operational perspective, Gen 2 isn’t only about higher performance—it changes how growth is managed. Teams should monitor workloads across HA pairs—tracking throughput, IOPS, latency, file server utilization, and storage utilization—to keep workloads evenly distributed and performance optimized.
Choosing the right generation for your workload
The most useful guidance for customers and partners is straightforward: align the FSx for ONTAP generation choice with workload requirements, growth expectations, operational needs, and regional availability.
If the workload stays within predictable single-HA-pair limits, Gen 1 is likely to be the right fit. If it has substantial performance spikes or future scale-out requirements, Gen 2 should be evaluated during the initial design stage.
Start by understanding how the workload behaves:
- Measure peak throughput, IOPS, and workload mix, and define the target AWS Region.
- Assess growth, variability, and concurrency patterns.
- Decide how much scaling flexibility will be needed over time.
- Check whether the workload needs a Gen 2 exclusive capability—such as NVMe/TCP, SSD shrink or faster restore access—independently of scale.
Some workloads can be sized upfront with confidence. Others need higher throughput at specific times, followed by periods of lower usage. Matching the deployment model to these patterns can help improve efficiency and avoid over- or under-sizing.
Summary
FSx for ONTAP provides deployment options for a wide range of workloads, with two generations that support different requirements.
Gen 1 remains a practical and often cost-effective choice for environments with predictable growth, stable performance requirements, or moderate scale. Gen 2 is worth evaluating when the workload has large datasets, variable demand, high concurrency, or evolving scale requirements.
The decision should start with workload behavior, not generation labels, as both generations deliver almost the same ONTAP capabilities and the same management tooling. If the workload would benefit from scale-out flexibility and resource optimization at scale, Gen 2 might be the better fit. If not, Gen 1 might remain the simpler and more efficient architecture.
In short, here are three steps to success:
- Understand your workload patterns.
- Use those patterns to guide the architecture decision.
- When sizing isn’t straightforward, engage AWS, NetApp, or partner solution architects.
For more information about FSx for ONTAP, visit the Amazon FSx for NetApp ONTAP customer page.
You might also find the following NetApp blogs useful:
Right sizing Amazon FSx for NetApp ONTAP instances for performance
Decreasing SSD storage capacity provisioned on Amazon FSx for NetApp ONTAP file systems
