Are the ports going into s - suspended state?
As a test, try to run the command no port-channel standalone-disable on the port-channel interface. You will need to bounce the port-channel interface.
if you set up VLANs on the controller side, on the trunk ports on the switch you need to allow at least the tags used on the storage side.
In Switch Side:
I configured to allow all tags. unsuccessfulI configured to allow specific tags. unsuccessful
The configuration on the Switch side
Core cisco WS-C6513
interface TenGigabitEthernet1/9/4
description Ligacao NETAPP AFF
switchport
switchport trunk encapsulation dot1q
switchport trunk allowed vlan 1,2,4,16,20,25,40-44,70,71,101,102,220,225,332
channel-protocol lacp
channel-group 100 mode active
interface TenGigabitEthernet2/9/4
