AFF
not enough spare disks
ggilles
hi,
since a few days, i 've got the following message at the bottom of the web page admin :
There are not enough spare disks. /aggr0/plex0/rg0: Please add spare disks to any pool supporting block checksums with minimum.
but, sysconfig command display :
filer-***> sysconfig -r
Aggregate aggr0 (online, raid_dp) (block checksums)
Plex /aggr0/plex0 (online, normal, active, pool0)
RAID group /aggr0/plex0/rg0 (normal)
RAID Disk Device HA SHELF BAY CHAN Pool Type RPM Used (MB/blks) Phys (MB/blks)
dparity 0c.00.6 0c 0 6 SA:B 0 SATA 7200 847555/1735794176 847884/1736466816
parity 0c.00.1 0c 0 1 SA:B 0 SATA 7200 847555/1735794176 847884/1736466816
data 0c.00.2 0c 0 2 SA:B 0 SATA 7200 847555/1735794176 847884/1736466816
data 0c.00.3 0c 0 3 SA:B 0 SATA 7200 847555/1735794176 847884/1736466816
data 0c.00.4 0c 0 4 SA:B 0 SATA 7200 847555/1735794176 847884/1736466816
data 0c.00.7 0c 0 7 SA:B 0 SATA 7200 847555/1735794176 847884/1736466816
data 0c.00.10 0c 0 10 SA:B 0 SATA 7200 847555/1735794176 847884/1736466816
data 0c.00.9 0c 0 9 SA:B 0 SATA 7200 847555/1735794176 847884/1736466816
data 0c.00.8 0c 0 8 SA:B 0 SATA 7200 847555/1735794176 847884/1736466816
data 0c.00.5 0c 0 5 SA:B 0 SATA 7200 847555/1735794176 847884/1736466816
data 0c.00.0 0c 0 0 SA:B 0 SATA 7200 847555/1735794176 847884/1736466816
Pool1 spare disks (empty)
Pool0 spare disks (empty)
I don't understand why ?
somebody tell me what can i do ?
thank
3 REPLIES 3
TMACMD
how about these outputs:
1. system node run -node node-01 disk show -a
2. disk show
andris
Please read this document section:
https://docs.netapp.com/ontap-9/topic/com.netapp.doc.dot-cm-psmg/GUID-4D43889E-7200-46D3-8182-A6AD836FE317.html
Specifically:
TMACMD
Looking at the list supplied, there are 11 disks.
Either one is broken or missing. Trying to see if that is the case.
