Dear Professionals,
I have 2 FAS2520s, all with sigle controllers.
Is it possible to create a node Cluster from them (switchless maybe)?
There are 12-12 identical discs in each of them2.
I would use them for NFS.
Thanks for your answers,
_Peter
Oh sorry! Someone asked the same question in there at about the same time.
Do you want data in place?
Assuming no - boot each node up to maintenance mode, using the special boot menu (control-c when prompted) and run this on each node:
ha-config modify controller ha
ha-config modify chassis ha
Then reboot and run option 9a from each system, then reboot and run option 9b from the system that says "LOADER A>". It will then prompt you to setup ONTAP again. You will need to re-enter the license details at this time.
Hope this helps.
Hi, I'm guessing this has been answered on Discord. Please let us know if you need any further assistance 🙂
Thanks for your answer.
Can you help me out with a link or reference, I am not using Discord yet.
Thanks in advance,
Thanks Alex
Does it mean, that the 2x12 disks will be visible in the Cluster, and can be used to create aggregates and maybe a single big volume (Now we have 2x12x2TB disks in them)
Yes - they will be partitioned first, to create boot partitions, but there will be a small root/boot partition and the remainder available for storing data on.
Thanks!
It make sense.
