ONTAP Hardware
FAS2552 Fibre Channel Slowly Speed to Dell Vmware
grax
Hello! I have a problem with disk read/write via FC (NetAPP Fas 2552 and Vmware Dell R640).
I have 2 channels FC online 8gbps - connections are ok. If i Power on some Virtual Machine (Windows 2019 Server) it`s start very slowly and on working Console (start Internet Explorer etc) a long time...
What is the reason?
To storage are connected 2 other servers via FC too.
Here my Test Speed on Windows Server 2019 Virtual Machine:
Help me pls 😕 It`s correct speed?
4 REPLIES 4
cedric_renauld
Hi Grax,
I've some questions for you 🙂
- Wath's your vSphere version ?
- How many disk have you in your NetApp ?
- This disk are shared betwen the 2 controlers ?
- Your VMDK arent in Thin provisioning ?
Thanks
grax
- vSphere 6.7U1
- 12disks SAS and 12disks NLSAS
- Yes, i have 2 controllers
- Yes Thin provisioning
grax
I have 2x 16Gb Fibre Channel GBIC
Look read speed is ok but write no.
I don`t know why 😕 Who help me?
cedric_renauld
Hummmm
I know the versions are not the same, but could you check tjis Vmware post :
https://communities.vmware.com/thread/564087
Dont forget th page's 2 of this
