ONTAP Hardware
How can I use the IBM N6240 Controller with NetApp FAS3240 Chassis?
wuijolskd
N6240 Controller was stocked last week. I connected and booted to the NetApp FAS3240 Chassis.
'Chassis midplane is not compatible with the install
Shutting down: Unsupported configuration.'
The message will be sent and automatically rebooted.
Is there any way to use the N6240 Controller with FAS3240 Chassis?
1 ACCEPTED SOLUTION
1 REPLY 1
