Software Development Kit (SDK) and API Discussions
volume "Tags" property always empty with Powershell cmdlet "get-ncvol"
yala37
Hello Everyone,
I'm trying to get my volume tags set via System Manager with the simple powershell cmdlet "get-ncVol", but "Tags" property is always empty.
I've also try the cmdlet with "-zapiCall" parameter, but having the same empty result.
powershell SDK 9.15.1.2407
powershell 5.1
Windows 2019
Ontap 9.14.1P8
thanks in advance.
Yala
1 REPLY 1
mattglg
Im getting the same issue as this with version 9.18.1.2601 of the PS module, I ended up having to use a api call to grab the tags.
function  Get-ONTAPVolTags {
    param (
        [Parameter(Mandatory,
            ValueFromPipeline)]
        [string]$clusterName,
        [Parameter(Mandatory)]
        [string]$volUUID,
        [Parameter()]
        [ValidateNotNull()]
        [System.Management.Automation.PSCredential]
        [System.Management.Automation.Credential()]
		$creds = [System.Management.Automation.PSCredential]::Empty
    process {
    $apiquery = "https://$clusterName/api/storage/volumes/$($volUUID)?fields=uuid%2Cname%2C_tags&return_timeout=120"
    # Send the API request to get volume information
    $result = Invoke-RestMethod -Method GET -Uri $apiquery -Credential $creds
    # Return
    $result._tags -replace(':','=') |ConvertFrom-StringData
    }#END PROCESS
}#END FUNCTION
