Hi Jai
Try this (worked in my lab using a simulator)
Import-Module DataONTAP
Connect-NcController -Name cluster1.testlab.local -HTTPS -Credential (Get-Credential -Credential admin) | Out-Null
$nodes = Get-NcNode
$ports = Get-NcNetPort
ForEach($node In $nodes){
$ports = Get-NcNetPort -Node $node
ForEach($port In $ports){
$command = @("system", "node", "run", "-node", $node.Node, "-command", "ifstat", $port.Port)
$api = $("<system-cli><args><arg>" + ($command -join "</arg><arg>") + "</arg></args></system-cli>")
$output = Invoke-NcSystemApi -Request $api -ErrorAction Stop
Write-Host $("Executed Command`: " + $([String]::Join(" ", $command)))
Write-Host ""
Write-Host $("Port """ + $port.Port + """ on Node """ + $node.Node + """") -ForegroundColor Cyan
Write-Host ""
If($output.results."cli-result-value" -eq 1){
[Array]$lines = $output.results."cli-output".Trim().Split("`n")
$lines
Example output:
Name Address Vserver Version
cluster1.testlab.... 192.168.100.2 NetApp Release 9.1: Thu Dec 22 23:05:58 UTC 2016
Executed Command: system node run -node testc1n1 -command ifstat e0a
Port "e0a" on Node "testc1n1"
-- interface e0a (61 days, 11 hours, 46 minutes, 5 seconds) --
RECEIVE
Frames/second: 0 | Bytes/second: 0 | Errors/minute: 0
Discards/minute: 0 | Total frames: 18502 | Total bytes: 1258k
Total errors: 0 | Total discards: 0 | Multi/broadcast: 271
No buffers: 0 | Non-primary u/c: 0 | L2 terminate: 432
Tag drop: 0 | Vlan tag drop: 0 | Vlan untag drop: 0
Vlan forwards: 0 | CRC errors: 0 | Runt frames: 0
Fragment: 0 | Long frames: 0 | Jabber: 0
Alignment errors: 0 | Bus overruns: 0 | Queue overflows: 0
Xon: 0 | Xoff: 0 | Jumbo: 0
Reset: 0 | Reset1: 0 | Reset2: 0
TRANSMIT
Discards/minute: 0 | Total frames: 55534 | Total bytes: 2443k
Total errors: 0 | Total discards: 0 | Multi/broadcast: 0
Queue overflows: 0 | No buffers: 0 | Max collisions: 0
Single collision: 0 | Multi collisions: 0 | Late collisions: 0
Timeout: 0 | Xon: 0 | Xoff: 0
Jumbo: 0
LINK_INFO
Current state: up | Up to downs: 0 | Auto: on
Speed: 1000m | Duplex: full | Flowcontrol: none
Executed Command: system node run -node testc1n1 -command ifstat e0b
Port "e0b" on Node "testc1n1"
-- interface e0b (61 days, 11 hours, 46 minutes, 5 seconds) --
RECEIVE
Discards/minute: 0 | Total frames: 18507 | Total bytes: 1184k
TRANSMIT
Discards/minute: 0 | Total frames: 18527 | Total bytes: 1185k
Jumbo: 0
LINK_INFO
Executed Command: system node run -node testc1n1 -command ifstat e0c
Port "e0c" on Node "testc1n1"
-- interface e0c (61 days, 11 hours, 46 minutes, 5 seconds) --
RECEIVE
Frames/second: 20 | Bytes/second: 5094 | Errors/minute: 0
Discards/minute: 0 | Total frames: 26275k | Total bytes: 3152m
Total errors: 0 | Total discards: 0 | Multi/broadcast: 10996k
No buffers: 0 | Non-primary u/c: 0 | L2 terminate: 3239
TRANSMIT
Frames/second: 15 | Bytes/second: 6955 | Errors/minute: 0
Discards/minute: 0 | Total frames: 17565k | Total bytes: 11175m
Total errors: 0 | Total discards: 0 | Multi/broadcast: 98001
Jumbo: 0
LINK_INFO
Current state: up | Up to downs: 2 | Auto: on
Executed Command: system node run -node testc1n1 -command ifstat e0d
Port "e0d" on Node "testc1n1"
-- interface e0d (61 days, 11 hours, 46 minutes, 5 seconds) --
RECEIVE
Frames/second: 4 | Bytes/second: 244 | Errors/minute: 0
Discards/minute: 0 | Total frames: 14906k | Total bytes: 1020m
Total errors: 0 | Total discards: 0 | Multi/broadcast: 10999k
No buffers: 0 | Non-primary u/c: 0 | L2 terminate: 4079
TRANSMIT
Frames/second: 1 | Bytes/second: 51 | Errors/minute: 0
Discards/minute: 0 | Total frames: 4006k | Total bytes: 223m
Total errors: 0 | Total discards: 0 | Multi/broadcast: 95304
Jumbo: 0
LINK_INFO
Hope that helps
/Matt
