We have a large number of unmanaged SnapMirror and Vault relationships that are monitored by OCUM 9.5. Most of these are vaults that have a 12 hour lag, but we have some mirror volumes that replicate every 5 minutes.
Unfortunately the global "Lag Thresholds for Unmanaged Relationships" doesn't fit both types of relationships. e.g.
Warning is set to 150%
Error is set to 250%
Our 5 minute SnapMirror relationship produces an error if the lag exceeds 12m min 30 sec
Our 12 hour Vault relationship would produce an error after 30 hours.
There's one particular mirror relationship that exceeds the error threshold overnight whilst it processes data. We aren't concerned by the lag, but we do find it onerous that it generates an alert every day which in turn goes to our incident ticketing system.
If we increased the error threshold to only alert after 30 mins on the 5 min relationship (600%), it would mean we only receive a notification for failed backups after almost 3 days!
Is there a way to set thresholds per relationship? If not, are there any plans to introduce this in future versions?
Thanks,
Paul.
