Hi
I m using ontap 9.7P11 and i would like how i can see the content of a volume through the cli?
I have read some old post on that subject but didin't succéed in it.
As Paul already mentioned. Ideally, content should be read using 'data protocol' via their respective clients. But, if you want to see/list what's there in the volume (dir/file) you can always use 'ls' command from advanced mode at the node shell level.
From Cluster shell:
::> node run -node <node>Type 'exit' or 'Ctrl-D' to return to the CLInode-01> priv set advancedWarning: These advanced commands are potentially dangerous; usethem only when directed to do so by NetApppersonnel.
For example: On node-01, there is a volume called cifs_shre, if I want to list what's in it. I can use this cmd:node-01*> ls /vol/cifs_share...document.txt
This is not possible through the cluster shell.
then how can i see the content?
my problem is that two nfs client didn't see the same thing and i would like to know who is right
You don't with cluster commands. You do it from the client end. Maybe you could try browsing from a Windows client over CIFS.
Thanks for your answer.
I had already seen this and it failed.
But it was only because i didn't use the node on which the volume was attached but a node in an other HA PAIR
thanks for your help
