Hi,
Does anyone have an idea about what minimum permissions is required to connect to ontap?
I am using the default readonly role and every read command that I have tried works.
However in the auditlogs I keep getting an Insufficient privileges.
The Connect-NcController tries to write to a file /etc/powershell.
The audit log shows the following :
<netapp version='1.0' xmlns='http://www.netapp.com/filer/admin'><system-cli>^M <args>^M <arg>node</arg>^M <arg>run</arg>^M <arg>controller-a</arg>^M <arg>-command</arg>^M <arg>wrfile</arg>^M <arg>/etc/powershell</arg>^M <arg>;</arg>^M <arg>node</arg>^M <arg>run</arg>^M <arg>controller-a</arg>^M <arg>-command</arg>^M <arg>wrfile</arg>^M <arg>-a</arg>^M <arg>/etc/powershell</arg>^M <arg>// File generated by the Data ONTAP PowerShell Toolkit: powershell.usagelog.version=1: powershell.usagelog.lastupdated=1644250226: powershell.cmdlet.CONNECTNCCONTROLLER.count=1: powershell.cmdlet.GETNCVOL.count=1: powershell.usagelog.timestamp=1644250226: </arg>^M </args>^M <priv>advanced</priv>^M </system-cli></netapp>^M :: Pending:
