Hi All,
We have created an in-house monitoring dashboard for all our storage system. We are using AIQUM REST API to pull the Netapp information.
But recently we upgraded our AIQUM from 9.7 to 9.9P2 due Log4j vulnerability. Post the upgrade our data collector script is here few snippets from my script and the error I'm getting .
##set environment up for previous support for encryption
[Net.ServicePointManager]::SecurityProtocol = "Tls12, Tls11, Tls, Ssl3"
##set environment up for ignore certificate issues
if (-not ([System.Management.Automation.PSTypeName]'ServerCertificateValidationCallback').Type)
$certCallback = @"
using System;
using System.Net;
using System.Net.Security;
using System.Security.Cryptography.X509Certificates;
public class ServerCertificateValidationCallback
public static void Ignore()
if(ServicePointManager.ServerCertificateValidationCallback ==null)
ServicePointManager.ServerCertificateValidationCallback +=
delegate
Object obj,
X509Certificate certificate,
X509Chain chain,
SslPolicyErrors errors
return true;
Add-Type $certCallback
[ServerCertificateValidationCallback]::Ignore()
PS C:\Users>
$volumeresponses = @()
function get-aiqumpaginateddata {
param(
[string]$aiqumuri,
$Restheaders
[int]$offsetnumber = 0
$response = @()
$responserecords = @()
#testing variables
#$pagesize = 1
#$aiqumuri = "https://xx.xxx.xx.xx/api/datacenter/storage/volumes"
$response_total_records = (Invoke-RestMethod $aiqumuri -Method 'GET' -Headers $headers -UseBasicParsing).total_records
for ([int]$i = $response_total_records; $i -gt 0; $i= $i - 1000)
$response = Invoke-RestMethod "$($aiqumuri)?offset=$($offsetnumber)&limit=1000" -Method 'GET' -Headers $headers
$responserecords += $response.records
$offsetnumber += 1000
$i
$offsetnumber
$responserecords.count
$responserecords
#Pass the uri as shown in aiquim tutorial
$aiqumaggruri = "https://xx.xxx.xx.xx/api/datacenter/storage/aggregates"
$aiqumVolumeuri = "https://xx.xxx.xx.xx/api/datacenter/storage/volumes"
$aggrresponses = @{}
$volumeresponses = @{}
$aggrresponses_formatted = @{}
$volumeresponses_formatted = @{}
$aggrresponses = get-aiqumpaginateddata -aiqumuri $aiqumaggruri -Restheaders $headers
$volumeresponses = get-aiqumpaginateddata -aiqumuri $aiqumVolumeuri -Restheaders $headers
Invoke-RestMethod : The request was aborted: Could not create SSL/TLS secure channel.
At line:18 char:32
+ ... _records = (Invoke-RestMethod $aiqumuri -Method 'GET' -Headers $heade ...
+ CategoryInfo : InvalidOperation: (System.Net.HttpWebRequest:HttpWebRequest) [Invoke-RestMethod], WebException
+ FullyQualifiedErrorId : WebCmdletWebResponseException,Microsoft.PowerShell.Commands.InvokeRestMethodCommand
At line:18 char:32
