We have been using the NetApp Active IQ Unified Manager 9.10 for a short time. We noticed that the AIQUM does not update itself (e.g. in the 'Event Management' view). You always have to press the refresh button at the top right so that the view is updated. The problem occurs with different colleagues, so it is not an isolated case. We use Microsoft Edge version 102 (64 bit) as the browser. At the same time, we also use OCUM 9.5, which is also accessed via MS Edge 102 (64 bit). There is no problem there.
