Hi all,
I have been using the new version of PSTK 9.14.1 for a few days because I thought the previous bugs had been fixed.
But I will still have to use the switch "-ONTAPI" when connecting to the Netapp Cluster to get correct values.
Example:
CMDLET get-nccifsshare
Some wrong or no values are returned if the connection to the cluster is established without the ONTAPI switch and REST-API queries are used:
...profilename\documents> Get-Module
ModuleType Version Name ExportedCommands
Manifest 3.1.0.0 Microsoft.PowerShell.Management {Add-Computer, Add-Content, Checkpoint-Computer, Clear-Content...}
Manifest 3.1.0.0 Microsoft.PowerShell.Utility {Add-Member, Add-Type, Clear-Variable, Compare-Object...}
Manifest 9.14.1.... Netapp.Ontap {Add-NaAggr, Add-NaCifsShare, Add-NaCredential, Add-NaFpolicyExtension...}
Script 1.2 PSReadline {Get-PSReadlineKeyHandler, Get-PSReadlineOption, Remove-PSReadlineKeyHandler, Set-PSReadlineKeyHandler...}
...profilename\documents> nc clustername -Credential $ncred
Name Address Vserver Version
clustername 172.1.1.111 NetApp Release 9.12.1P10: Wed Dec 20 00:24:59 UTC 2023
...profilename\documents> $shares = Get-NcCifsShare -VserverContext vservername | select *
...profilename\documents> $shares | where {$_.sharename -like 'tmpshare$'}
Acl : {BUILTIN\Administrators / full_control, BUILTIN\Users / change, Everyone / full_control, ...}
AttributeCacheTtl :
CifsServer :
Comment :
DirUmask :
FileUmask :
ForceGroupForCreate :
MaxConnectionsPerShare :
NcController : clustername
OfflineFilesMode : manual
Path : /vol0815/q0815_11501
ShareName : tmpshare$
ShareProperties :
SymlinkProperties : {local}
Volume : vol0815
VscanFileopProfile : standard
Vserver : vservername
HomeDirectory : False
Oplocks : True
AccessBasedEnumeration : False
ChangeNotify : True
Encryption : False
NoStrictSecurity : False
AllowUnencryptedAccess : False
ShowSnapshot : False
ContinuouslyAvailable : False
NamespaceCaching : False
UnixSymlink : local
Browsable :
ShowPreviousVersion :
AttributeCache :
AttributeCacheTtlSpecified : False
DirUmaskSpecified : False
FileUmaskSpecified : False
MaxConnectionsPerShareSpecified : False
...profilename\documents> nc clustername -Credential $ncred -ONTAPI
Acl : {BUILTIN\Administrators / Full Control, BUILTIN\Users / Change, Everyone / Full Control, ...}
AttributeCacheTtl :
CifsServer : cifsservername_missed_on_restapi
Comment :
DirUmask :
FileUmask :
MaxConnectionsPerShare : 4294967295_missed_on_restapi
ShareProperties : {oplocks, browsable, changenotify, show_previous_versions}_missed_on_restapi
SymlinkProperties : {symlinks}_wrong_on_restapi
Volume : vol0815
VscanFileopProfile : no_scan_wrong_on_restapi
Oplocks : False_wrong_on_restapi
ChangeNotify : False_wrong_on_restapi
Encryption : False
UnixSymlink : _wrong_on_restapi
Browsable :
AttributeCache :
MaxConnectionsPerShareSpecified : True_wrong_on_restapi
In Addition I checked the return values of a direct REST-API call with System Mananger:
Here the important value of vscan_profile is correctly "no_scan" other than "standard". It means, the cluster is delivering the correct values to the REST-API call:
"name": "volume1",
"vscan_profile": "no_scan"
Kind regards
Holger
