An application owner pings Anna on Teams: "We need 500 GB for a new service, today, if possible." She knows the drill. She opens NetApp® ONTAP® System Manager on the target cluster to check aggregates, Active IQ Unified Manager to see whether anything is already alerting on that system, and NetApp Digital Advisor® to confirm capacity trends look healthy, each tool doing exactly what it was built to do.
The provisioning itself takes minutes. What takes longer is deciding where it should go: which cluster, which aggregate or SVM, whether it meets the storage class her architect defined, and whether anything else in the fleet would be a better fit. That decision means jumping between interfaces and drawing on experience, not because any one tool has failed her, but because no layer yet brings fleet context into the everyday work of running storage.
Sound familiar? This is the daily reality for teams managing on-premises ONTAP at scale, not because the storage isn't capable, but because the management experience has been fragmented within the estate. That gap is exactly why we built NetApp Console™ local deployment.
We're announcing the general availability of NetApp Console local deployment, a locally deployed, AI-driven autonomous control plane that brings fleet-scale management to your on-premises ONTAP estate for the first time as a unified Console experience.
This is a significant milestone for NetApp and for every customer running ONTAP at scale. Console local deployment delivers the management layer our on-premises customers have been asking for, fleet organization, unified observability, policy-governed provisioning through storage classes, and an AI-powered Console Assistant, all running inside your environment, on your terms. No constant cloud connection required. The same intelligent experience as NetApp Console in the cloud. One solution. Two delivery models.
Validated through our Early Access Program with customers across industries, Console local deployment is ready to change how teams organize, monitor, and act across their storage estates. Whether you manage ten systems or a hundred, this is the next chapter in how NetApp helps you take complete control of the NetApp Platform, locally, securely, and at fleet scale.
When Growth Outruns Your Tools
ONTAP was built to scale and your environment proves it. More systems, more sites, more workloads running on a platform you trust, supported by NetApp management tools that excel at the cluster and system level. Console local deployment extends that foundation with a fleet-scale layer designed for the estate you have today, and the one you're building toward.
For storage engineers, that means everyday work, such as provisioning, placement, troubleshooting, happens with fleet-wide context at your fingertips, so decisions are faster and better informed. For architects, it means the standards you define through storage classes and policies, reach every cluster consistently, without losing the depth of system-level management. For executives, it means a single, locally deployed view of capacity, health, and risk across your on-premises environment, built on the unified control plane and tools you already rely on.
Console local deployment doesn't change what ONTAP does. It unlocks what your team can do with it at scale.
A Different Kind of Control Plane
Console local deployment is designed to meet your storage management where you operate.
It runs locally, deployed as an OVA in your VMware environment. No constant cloud connection required. That matters for air-gapped sites, regulated industries, and any organization that needs management to stay inside its own infrastructure. Yet it delivers the same intelligent experience as Console in the cloud. One console, two delivery models, no retraining.
Think of it less as another tool and more as an autonomous control plane, a single place to organize your estate, understand what's happening across it, and act when something needs attention.
Organize the Estate, Not Just the Clusters
The story usually starts with fleet management. Instead of thinking cluster by cluster, teams begin grouping systems the way the business actually thinks, by region, by workload, by tenant, by business unit. A manufacturing site in Munich and a DR pair in Dublin can live in the same fleet. A system can belong to multiple fleets without being rediscovered or reconfigured.
For architects, this is where design intent starts to stick. Storage classes let senior admins define what "good" looks like, including performance, capacity, security, data protection, once. From that point on, every provisioning action, whether manual or AI-assisted, follows those rules. Engineers stop reinventing decisions they've made a hundred times. Executives get something they've wanted for years: consistency at scale.
See What's Happening Before It Becomes a Problem
Visibility comes next and for many teams, this is the moment things click.
Instead of piecing together health from scattered sources, Console local deployment brings monitoring, alerting, and analysis into the same place you manage the estate. Dashboards show what matters to your role.
When something looks off, the workload analyzer helps you drill down without hours of manual correlation. Alerts arrive with context. The audit trail is already there when compliance asks who changed what.
Intelligence That Respects Your Boundaries
The newest chapter in this story is the Console AI assisted ChatOps, and we know the first question is always the same: Is it safe?
We built it to be. Ask a question in plain language, what's wrong with a cluster, where to place a new volume, which storage class fits a workload, and the ChatOps responds in read-only mode by default. It can analyze and recommend without changing a thing. When you're ready for it to act, you switch modes explicitly. It uses your LLM, not ours. PromptGuard screens content before it reaches any AI. Every action respects the same RBAC permissions you already enforce. Everything is logged.
For engineers, that means less time on repetitive requests and faster answers when something breaks. For architects, it means AI that works within policy, not around it. For executives, it means the speed of intelligent automation without the compliance anxiety that usually comes with it.
Why This Moment Matters
The timing isn't accidental. Estates are growing while teams stay flat. Cloud providers have raised expectations for storage experiences, and on-premises environments need to keep up. Console local deployment brings it together: organize your estate, understand it, act on it, from one place that runs on your terms.
Call to action
If you're an executive, the conversation is about reducing risk, accelerating application delivery, and consolidating a sprawl of tools into one strategic platform. If you're an architect, it's about making standards real across a growing environment. If you're an engineer, it's about getting your Tuesday mornings back. Download NetApp Console local deployment from the NSS site now and unbox the opportunity to manage your Storage estate in the most advanced and smart way.
Talk to your NetApp team about a fleet workshop or proof of concept. See what it looks like when your on-premises estate is managed as one — not as fifty separate problems.
Take complete control of the NetApp Platform with Console autonomous operations.
Declare outcomes. Automate operations. Secure every action.
Excited to learn more? Read these blogs: Empower autonomous operations across your storage estate now and NetApp Console Autonomous Operations: From Managing Infrastructure to Declaring Outcomes
Want to kick the tires? Try guided demos, see videos, and access additional resources thru the Console Interactive Showcase.
Want to get educated? Take the Introduction to NetApp Console and NetApp Console Fundamentals courses
Ready to get started? Login into NetApp Console in SaaS.
