Good day Fellow Netapp Users,
I have a netapp with an interesting error:
Inband ACP is active on Port 0b keeps sporadically failing.
Node01 hat an hard reboot error of the ACP module, this was also visible in the shelf-log-iom log.
With this error we decided to replace node01 but the issue presists with the sporadic ACP errors.
We restarted both nodes both BMC and turned ACP off and on.
Since the issue presists we are thinking to replace the node02, since the system has no expansion shelfes. If the issue then presits my only thought is that the midplane of the Controller shelf is faulty.
System has one Controller shelf and is hosting CIFS/NFS
Any other ideas or would you also replace the other node?
