AFF
AFF 8060 & 8080 CPU Specs
CCIE17603
Can someone tell me what the AFF8060 and AFF8080EX CPU Specs are? When I look in hardware universe it says:
Processor:  8020 =  2 x 64-bit 6-core 2.00 Ghz | 8040 = 2 x 64-bit 8-core 2.10 Ghz | 8060 = 100 to 120, 200 to 240[3] | 8080EX = 100 to 120, 200 to 240[3]
I am completely baffled by the reference to:100 to 120, 200 to 240[3] (see the attachment) The attachement was right out of hardware universe and just downloaded as a pdf.
I read aomewhere in tech-rag that Intel was developing a Haswell E5-2600 v3 for the likes of NetApp and EMC. Is that whats in there? If so how many sockets and cores???
Thanks everyone.
2 REPLIES 2
Sahana
Hi
I think the table values for input power voltage and processor got interchanged. refer the attached image.
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
PhilippeHELLEC
Hi
per controller :
8020 : 1* Sandy Bridge E5-2620 6 CORES 2.0 GHZ
8040 : 1 * sandy brige E5 8 CORES 2.1 GHZ
8060 : 2 * sandy brige E5 8 CORES 2.1GHZ
8080 : 2 * sandy brige E5 10 cores 2.8GHZ
regards
